Dynon D180 alerts too loud.
Davwol
Member
Dynon D180 sends audio alerts to my Xcom radio/intercom. Is there a way to adjust the volume down for the alerts (autopilot disengage)?
RV9A
I would say yes - -
While building the 12, they had us go thru a setup of vol(s). on rear of unit.
EDIT : We had to adjust on the 'mother board'. Not sure how others are set up.
You might want to think about an audio taper pot rather than linear taper. It?ll probably be less touchy to adjust.
I had the same issue with a D6. I cut the wire to the audio panel (intercom), used alligator clips to insert a series resistor. Tried 1K, 3K, 5K ohms, etc., until the volume was about right. Soldered the correct resistor in series, added a stiff insulated piece of wire plus shrink wrap for support.
