Old 06-13-2011, 08:15 AM
Snowflake's Avatar
AC 43.13 is available digitally for free from the FAA website... I don't have a link handy because I'm on my iPad right now, but I've downloaded it a few times from them.
Rob Prior
Old 06-13-2011, 08:26 AM
Auburntsts's Avatar
That's were I got my copy -- last time I downloaded it was just a few weeks ago.
43.13-1B Acceptable Methods, Techniques, and Practices - Aircraft Inspection and Repair dated 1998 and
43.13-2B Acceptable Methods, Techniques, and Practices – Aircraft Alterations dated 2008
-1B is the volume germane to this discusson and is generally the one that everyone is referencing when qutoing 43.13.
Todd Stovall
PP ASEL-IA
RV-10 N728TT - Flying!
WAR EAGLE!
Old 06-13-2011, 12:24 PM
Jerry Cochran's Avatar
Jerry Cochran Jerry Cochran is offline
Default CoastFab
This source might help.
http://www.coastfab.com/torque_fastener_matching.html
Jerry Cochran
Sherwood, Oregon
RV-7a 707DD Bot from David Domeier 12/01/11
Lycoming IO-360 Catto 3 blade Panel upgrade in progress
RV6a 18XP 1st flite 03/21/07 sold to Dale Walter 10/22/2011
Superior IO-360, Hartzell Blended, GRT/Dynon
Happily "autopaying" DR
"Suppose you were an idiot, and suppose you were a member of Congress; but I repeat myself."
Mark Twain
Old 06-13-2011, 12:48 PM
Auburntsts's Avatar
Jerry,
Thanks for the link. Getting closer to an answer I think. Sooo anybody know if the wing attach bolts are tension or shear (I'm guessing shear)? Makes a 200 in-lb difference in torque on a NAS1307 bolt according to the chart on the link in Jerry's post. That's a pretty signifcant difference in my book and not something I want to get wrong.
Todd Stovall
PP ASEL-IA
WAR EAGLE!
Old 06-13-2011, 01:16 PM
krw5927 krw5927 is offline
Default Shear
The spar attach bolts are loaded in shear. Double shear, to be technically correct, with the spar sandwiched between the two center section blocks. Here's an example:
http://www.instron.us/wa/solutions/N...exZKvRykObvZx4
Torque for shear.
Kurt W.
RV9A
FLYING!!!
Old 06-13-2011, 05:57 PM
jthocker's Avatar
jthocker jthocker is offline
Torque for shear.
So, I go to the trouble of searching for my old AC 43-13, finding the TORQUE that we've been using for years, give the torque range for everybody so they have it for posterity, and somehow that isn't good enough!
The table I got the torque values from are for steel tension nuts, the nuts that are called for are AN365! STEEL TENSION NUTS!
If you want to use AN364 shear nut torque values make sure you print that on the side of the plane so everybody who rides in your plane will know your plane has LOOSE wings!
Jon Thocker
Habitual Offender
RV4, RV4, RV6A, RV8, RV8, RV8,RV8, RV8, RV8, RV12
Old 06-13-2011, 06:08 PM
Auburntsts's Avatar
Why are the simplest things never easy? Guess I'll torque to type of nut listed in the table.
Todd Stovall
PP ASEL-IA
WAR EAGLE!
Old 06-13-2011, 07:10 PM
Yep, I'm sure my plane will fall out of the sky.
Torque for tension, won't hurt a thing. The bolts are not primarily loaded in tension, though. This is a shear load configuration.
Kurt W.
RV9A
FLYING!!!
Old 06-13-2011, 09:15 PM
GLPalinkas's Avatar
GLPalinkas GLPalinkas is offline
Default Thanks for your help Jon
Jon, Just a quick note to say that I bookmarked your answer right away. You are one of the "Go-To" guys that a lot of people on this site turn to for advice. I wanted you to know that not everyone second guesses your experience ....THANKS
Gary Palinkas - Gman.... VAF #161
Venice, Fl
RV-6 "Sassy" Flying 400 hrs since Oct 2011
Lycoming 0-360 A1A, FP Sensenich Prop
SARL #19 .... Van's Calendar March 2015
Although exempt several ways, =VAF= Dues paid to support this awesome site/family
Old 06-13-2011, 09:36 PM
Please accept my apologies for "second guessing" a moderator. Sorry, Jon. I have learned my lesson and will not attempt to help others from now on.
Surprised, actually, that such an indignant response came from a mod. Or maybe I didn't understand the tone of the response properly.
