Old 08-09-2018, 10:58 AM
Latech15 Latech15 is online now
Default New RV Owner
I have finalized the purchase of an already flying RV6A, and will be going out to pick up the plane this weekend. Thanks to all who have helped me get connected with a ferry pilot/transition trainer. He will be flying most of the way back home (from California to Louisiana) with me and doing the training along the way. The plane is a 2013 completed model with skyview touch PFD/MFD dynon AP with a GTN650 navigator. I can't really describe how excited I am about owning my first plane and the trip back to get her home.
I wanted to start this post so I could post pics of the pickup and the trip back.
Old 08-09-2018, 01:24 PM
Dugaru's Avatar
Dugaru Dugaru is offline
Default Good luck!
Very wise of you to get some extended time with a transition instructor. My -9A is hardly difficult to fly, but I still learned a LOT of useful stuff from a guy who really knew RVs.
N929JA, 2007 RV-9A
Based W96 - near Richmond, VA USA
2019 Dues Paid
Old 08-10-2018, 04:39 PM
gerrychuck gerrychuck is offline
Congratulations! I acquired my flying 6A 7 years ago now, and it still puts the same grin on my face every time I fly it. Your time in transition training should serve you very well; the 6 is not a difficult airplane to fly at all, but it's not like most GA planes either, so once you understand the differences and accommodate to them, it's just a sweetheart. Wishing you a great flight home!
Gerry Julian
Moose Jaw Saskatchewan
RV6A "Second Wind" C-GERZ (born N242UL)
O-360 A1A, Sensenich FP prop
Those who think any system is foolproof greatly underestimate the ingenuity of fools
Old 08-14-2018, 05:12 PM
Jonathan Alvord Jonathan Alvord is offline
I agree with Dugaru. I just bought my RV7a and had the same thoughts, I'll get the training on the way to Oregon from Florida with Mike Seager. I was a new pilot with 43 hrs, but landings and take offs are very different from a 172. Took 2 days to get to Oregon with several landings, and another 3 days in Oregon. Lots of discussion along the way picking his brain but that didn't meet the experience needed to land the plane and feel comfortable. Now I have over 100 hours since June on the plane and still have lots to learn. Have fun, The RV's are great!
N122EF RV7A
KPGA
=VAF Dues paid 2018=
Old 08-14-2018, 05:37 PM
I made it back last night with lots of stories and cool experiences. The trainer that flew with me was great and I highly recommend him for training or ferrying if you have a need for either.
We made it from KSMX to KPVW the first day with a few fueling stops along the way. The 6/6A is a 2 hour plane. It holds more fuel than that, but you definitely want to get out and stretch your legs after that. We got up the second day and did lots of touch and goes before battling weather around Dallas. I dropped him off at KDAL and left there on my own the rest of the way to Louisiana. I was a little nervous leaving out of there on my own, but it turned out to be no different than leaving my home non-towered airport, just a longer line and lots of taxi instructions. The landing back home was great. I was a little concerned about it so I told my family that I would be there about 20 mins after my scheduled arrival so they wouldn't witness my going around or bouncing the landing! In the end, I landed it and just chilled out in the plane waiting for them to arrive.
Ill figure out how to upload images and post them shortly.
Old 08-15-2018, 08:56 AM
AndyRV7's Avatar
AndyRV7 AndyRV7 is offline
I remember this experience too. Enjoy the plane!!
Old 08-16-2018, 11:26 AM
Couple questions -
#1. I am having a really rough mag drop on one pmag. The plane has dual pmags. Either timing issue or a fouled plug. Previous owner/builder says he never saw either. Replacing the plugs seems like the easiest fix since trying to burn off the fouling didnít work. Any advice here or suggestions would be helpful.
Also, Iím figuring out the software update deal with the Garmin and the Dynon systems. It seems like these will take a little time. The previous owner had a portable power supply that he could plug into the cigarette lighter that fed the ebus, but I canít seem to find anything online about that. What are you guys doing for ground power?
Old 08-16-2018, 11:42 AM
n981ms's Avatar
n981ms n981ms is offline
If your efis is logging engine data it can help decipher mag vs plug. Also which cylinder is offending so you know where to focus your attention.
Maxwell Duke
Kitfox S6/TD/IO240/SteamIFR Built it
RV10 IO540/AFS5600x3 Bought it
CH750 O200/AFS5500. Built it with 7 friends. DAR-Vic Syracuse
Maule M7-235C Sold it(kind of miss it)
VAF paid 5/2017
Old 08-16-2018, 03:36 PM
Pretty sure it is #3. It is running a little hotter than the rest.
Old 08-18-2018, 04:32 PM
One problem solved, another pops up....
The bad mag check was caused by the bottom spark plug wire on the #3 cylinder coming off the plug. Found it before I took the lower cowl off. She runs up just fine now.
On todays flight, my GTN650 kept flip flopping and eventually went to 121.50 as if you were holding down a remote flip/flop switch. This happened after flying through some rain, so I am going to check and make sure that I don't have water getting in somewhere.
Still need to replace a #4 CHT probe as well.
Im completely at a loss as to the visual approaches on the GTN 650. I simply don't know where it is taking me. I am within 10 miles of the airport on an extended left base. I activate the visual and the AP turns me WAY in the wrong direction and tells me that I am 25 miles from the destination. I have tried this a few different ways and I always end up shutting it off. Anybody care to hold my hand on visual approaches?
