cdeerinck
I'm looking for any feedback on the fuel lines in this picture before making it permanent. This is for a EFII fuel injection setup. Two lines are missing from the picture. From the top of the fuel filter into the gear tower, and the return line from the firewall to the gear tower, which will be nearly straight, and next to the fuel pumps.
The side plate will be riveted via a piece of angle aluminum sheet at the bottom center. But even without that, the pump can't move.
The stud holding the filter is by Click-Bond, but I could drill into the tower, and use a bolt from inside if there is good reason to.
None of the lines are under any lateral pressure, but the fit is tight. I will be able to remove any of the lines, pumps, and filter after the final installation.
This is my first build, and I want to make sure I'm not doing anything dumb.
