Hi Folks,
May I ask you which rod end bearings you are using for the Rear Throttle Lever for Vans RV8 from Aircraft Spruce?
See the link below for the throttle lever 05-04531:
http://www.aircraftspruce.com/catalog/appages/rv8quadrant.php?clickkey=8822
I found that the eyeball bearing - which would be used for the Vans rear throttle - is to wide and does not fit between the lever and the lever bracket from Spruce...
Pictures would be highly appreciated...
Thank you very much for your support!
Best wishes,
Anna
Best wishes,
Anna
