Old 04-04-2012, 02:01 PM
Catbird Catbird is offline
Thanx, Mel. I thought that thing was kinda heavy.
Old 04-04-2012, 02:57 PM
DonFromTX's Avatar
Here is all you need, on stainless:
Retired US Army Officer
Old 04-04-2012, 03:36 PM
krw5927 krw5927 is offline
Goodness, Don, are you really calling your airplane "Air Force 1"?
I imagine you'll have no problems at all transitioning the DC SFRA
Kurt W.
RV9A
FLYING!!!
Old 04-04-2012, 03:42 PM
DonFromTX's Avatar
Well, I DO expect some preferential treatment sometimes. Like when I say "This is Air Force 1 and I am going to try to bring this sucker in on only one engine", ought to clear the airspace a little.
Old 04-04-2012, 04:37 PM
curtis's Avatar
curtis curtis is offline
Originally Posted by Catbird View Post
Shouldn't the Manufacturer on the aluminum data plate be engraved with "Van's Aircraft, Inc." instead of "Vans Aircraft Inc." ?
Should not the Mfg name be the builders name and not Van's?
RV-6A Slider
550 hours +
Build it light and cheap
Old 04-04-2012, 04:43 PM
DonFromTX's Avatar
Not for an ELSA (which most 12's are), you are not the builder, just the assembly grunt. No billing on the data plate.
Old 04-04-2012, 06:14 PM
KALEWIS's Avatar
KALEWIS KALEWIS is offline
Aren't you EAB don?
Airspeed, Altitude, or Brains...you need at least two
RV-12 #328
At 435 Hrs on the Hobbs
Old 04-04-2012, 07:23 PM
Dvalcik's Avatar
Dvalcik Dvalcik is offline
Default Eab
Originally Posted by Mel View Post
The only information required on the data plate is:
Manufacturer......VANS AIRCRAFT INC.
Model.................RV-12
Serial Number.....120XXX
Officially the date of manufacturer is the date the airworthiness is issued. If you want to put a date, just use the month and year of the expected A/W issuance. You should pretty well have that nailed down in time to do the data plate.
Mel what if it is a EAB rv12 not a Elsa?
I would not list Vans as the manufacturer correct?
Can I use my kit number?
I am about to start my paper work - this is good timing for this thread
David
EAA 1434 KBST
Belfast, ME
david@rv12pilot.com
2019 VAF Supporter
RV12 #568 EAB
* Started 9/30/2011
* 1st flight 8/30/12
http://www.rv12pilot.com
Old 04-04-2012, 08:51 PM
DonFromTX's Avatar
Yes, that is why I can call myself the manufacturer and call it anything I want to. After all that work, I felt I should have my name on the tag. Besides it is more fun this way. In answer to another post, yes you can put any serial number you feel like on it.
Originally Posted by KALEWIS View Post
Aren't you EAB don?
Old 04-04-2012, 08:56 PM
Dvalcik's Avatar
Default EAB plate
Thanks Don just verifying
David
EAA 1434 KBST
Belfast, ME
david@rv12pilot.com
2019 VAF Supporter
RV12 #568 EAB
* Started 9/30/2011
