Old 06-09-2008, 06:43 PM
N941WR's Avatar
N941WR N941WR is offline
Default Data Plate?
I recently had a two time builder tell me that E-AB aircraft have to have a non-destructive type data plate mounted in the cabin, in plain view.
Have any of you ever run into this before?
I do know you have to have one on the tail, but I have never heard of having one in the cabin.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 06-09-2008, 07:45 PM
Larco Larco is offline
Have had several different inspections by different inspectors and DAR's and they only required the Data plate on the exterior. Larry
Old 06-09-2008, 08:33 PM
170 driver 170 driver is offline
FAA Advisory Circular 45-2C Page 5,,,,has the info...Look in FAA.GOV website in Regulatory and guidance library under advisory circulars. Exterior is all that is required near tail, or rear most entrance door.
Old 06-09-2008, 08:34 PM
RV6_flyer's Avatar
See Larry's post for the correct answer.
Here is a link that will take you to the actual FARs on what is required.
http://www.rvdar.com/FAR_45.htm
Read FAR 45.11.
Gary A. Sobek
NC25 RV-6
Flying
3,400+ hours
Where is N157GS
Building RV-8 S/N: 80012
Old 06-09-2008, 11:49 PM
az_gila's Avatar
az_gila az_gila is offline
Smile Old rules - very old rules...
Bill... very old rules.... the interior data plate was required before the FAA/DEA did their "drug thing" in the 80's and wanted all planes to have an exterior ID plate.
Made it somewhat difficult for the fibreglas glider owners who wanted flush surfaces, and they now have a written FAA exemption...
You info sources must be very old...
gil A
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 05-24-2010, 06:05 PM
yankee-flyer yankee-flyer is offline
Default More Data Plate questions
I looked through the previous postings but some of them seem contradictory and I have another question.
Date of manufacture: If I use the date of inspection then the data plate can't be on the aitplane for the inspection. Is the correct date the date of the original airplane Van's built, kit ship date, final assembly date, or ????
Empty Weight: I'd take that to be the empty weight of 143WM, but that's not the airplane manufactured by Van's-- that's the red one. Still, seems like it should be 143WM???
Thanks !!!!
Wayne 120241/143WM
Everything done but FF, started that.
Old 05-24-2010, 06:42 PM
Peterk Peterk is offline
don't need empty weight or date. do need mfr, serial number, engine
Old 05-24-2010, 08:43 PM
Mel's Avatar
Mel Mel is offline
The only information required on the data plate is:
Manufacturer......VANS AIRCRAFT INC.
Model.................RV-12
Serial Number.....120XXX
Officially the date of manufacturer is the date the airworthiness is issued. If you want to put a date, just use the month and year of the expected A/W issuance. You should pretty well have that nailed down in time to do the data plate.
A&P/EAA (LifeTime) Tech Counselor/Flight Advisor/Nat'l Test Pilot School
<rvmel(at)icloud.com>
North Texas (8TA5)
RV-6 Flying since 1993, 172hp O-320, 3-Blade Catto (since 2003)Sold
Legend Cub purchased 12/2017
FRIEND of the RV-1
Eagle's Nest Mentor
Old 04-04-2012, 12:44 PM
Catbird Catbird is offline
Shouldn't the Manufacturer on the aluminum data plate be engraved with "Van's Aircraft, Inc." instead of "Vans Aircraft Inc." ?
Old 04-04-2012, 12:54 PM
Mel's Avatar
Mel Mel is offline
The manufacturer on the data plate must be "exactly" as listed on the registration. Typically FAA does not use punctuation on registration certificates.
BTW, the data plate should be stainless steel, not aluminum.
North Texas (8TA5)
FRIEND of the RV-1
Eagle's Nest Mentor
