Old 09-13-2018, 11:53 AM
kg6kct kg6kct is offline
Default Looking to buy Rv6,7,9A engine mount with gear leg
I'm helping a friend who needs a engine mount and gear leg for an rv6a project. Can be conical or dynamical .
Please send pictures and description .
Old 09-14-2018, 04:21 AM
von_flyer von_flyer is offline
I have a 7A nose gear if that helps.
John von Linsowe
Michigan
Cessna 140
Old 09-14-2018, 09:11 AM
Default Gear leg
Sent Von flyer a email
Old 09-14-2018, 09:24 AM
dmat dmat is offline
I have a 6A nose gear leg and fork.
D
RV6A - N6389 - flying regularly
Old 09-15-2018, 08:02 AM
Kevin R Kevin R is offline
Default Mount
Good morning,
I have a new motor mount and gear legs if your interested. Never mounted.
I'm converting my 6A to 6.
Kevin R
Old 09-15-2018, 08:29 AM
Default Engine mount
Pm sent to Kevin
Old 09-17-2018, 09:03 AM
Breezy Breezy is offline
I have an RV-6A engine mount and nose wheel strut.
Removed due to retainer bolt wear. Already drilled to AN6 bolt. Could be welded and rebored to AN5, or possible a taper pin. Otherwise in good shape.
PM me if you want pix.
Breezy
First offense RV-8; N594WR; 80594 (time served)
ECI TITAN IOX 360 A1A9N, G3X
Repeat Offender: 83137 (Flying 10/16)
N837DW; Superior IO 360; G3X Touch.
Exceptional Aircraft Award, Sun N Fun 2017; Best Homebuilt, Mid-Eastern Regional Fly-in 2017.
One More Time: 140359, -14 in process, IO-390 (Maybe)
KHAO (Hogan Field)
