Old 09-11-2018, 07:38 PM
Azjulian Azjulian is offline
what are your EGTs ? and what do you spark plugs look like ? Just interested in if your mixture is rich.
Old 09-11-2018, 09:05 PM
DaleB's Avatar
DaleB DaleB is offline
Originally Posted by pilotyoung View Post
Thanks for all the information. I am going to check the prop pitch and see what rpm I get wot at altitude on the next flight.
Also check WOT RPM on the ground, no wind, with the engine at operating temperature (meaning oil temp. at 180 or higher). Static RPM should be 4960 to 5020.
The fuel computer is not calibrated correctly so I will be working on it also. The fuel gauge seems to be 1 gallon high which is OK with me.
While I am new to the RV-12, I have been landing with 5 gallons of fuel.
Not a bad policy. I generally like to land with 5 gallons, although over the past year or so I've been known to let it get lower if the conditions and schedule justify it.
Dale
Omaha, NE
Previous RV-7 project (sold)
Old 09-11-2018, 09:07 PM
pilotyoung pilotyoung is offline
Default Fuel Burn
Looking back at some pictures I took of the Skyview, last Saturday they were:
6500 MSL 5300 RPM Left 1184 Right 1204
5500 MSL 5420 RPM Left 1251 Right 1279
A couple of weeks ago
3020 MSL 5100 RPM Left 1313 Right 1312
2500 MSL 5270 RPM Left 1318 Right 1326
