Old 09-10-2018, 09:37 AM
paulmiller's Avatar
paulmiller paulmiller is offline
Default AFS 4500sEE CHT EGT probes, Crossbow for sale
Recently removed for G3X upgrade, this would make a nice economy EFIS, engine monitor setup.
-AFS 4500sEE with synthetic vision, engine monitor combined.
-red cube fuel flow
-oil pressure sender
-oil temp sender
-fuel pressure sender
-EGT probes, 6 used, 2 new.
-CHT probes, 7 used
-Crossbow AHRS CRM 300CA-100, p/n 8350-0480-03
All of this for $2500, all working, no harnesses. Plenty of pictures available. Can ship almost anywhere so ask.
Old 09-10-2018, 09:55 AM
fasilpereira fasilpereira is offline
Sending PM now.
Old 09-11-2018, 05:08 PM
Paul, I'll pass on the AFS 4500S. Thank you!
Old 09-12-2018, 07:24 AM
paulmiller's Avatar
THanks for looking. Apologies for thinking SP was Spain, realize now it is São Paulo. Either way, it could have been shipped.
Paul
Old 09-13-2018, 01:41 PM
Machsandy Machsandy is offline
Default AFS 4500
Paul, trying to read the 4500 IM there seems to be a 4500p which is held by 4 screws on the panel and the 4500 which is held by a tray. Which version do you have and if it is the 4500 is the tray included?
If it is a tray is it riveted to the panel?
Old 09-13-2018, 02:38 PM
paulmiller's Avatar
Take a look here, I think that the screw-into-the-panel version? Move quickly, I think it is in a hurricane by now. I'll get more data if that isn't clear.
Old 09-14-2018, 06:29 AM
paulmiller's Avatar
Can someone tell me if this is a tray mount or panel mount AFS 4500? The owner is in the middle of the hurricane today so I can't really get an answer for people. Thanks.
Old 09-14-2018, 08:18 AM
Larco Larco is offline
Because of the flange around the front I think they are slide in type needing a tray. I had panel mounts and they did not have this type of flange. To be sure I would call support at AFS and have them look at your photo here, They would I'm sure be glad to help? Here is an example of the panel mount
Old 09-14-2018, 08:49 AM
rleffler's Avatar
rleffler rleffler is offline
I believe all 4500s used the panel mount tray to help support the EFIS due to its weight and depth. The newer models are much lighter and about half the depth.
Bob Leffler
N410BL - RV10 Flying
http://mykitlog.com/rleffler
Old 09-14-2018, 09:10 AM
Jesse's Avatar
Jesse Jesse is offline
I think some of the 4500’s were rear mount in the early days. This one looks like the tray-mount version.
352-427-0285
jesse@saintaviation.com
