Go Back   VAF Forums > RV Firewall Forward Section > Propellers
Old 09-11-2018, 05:18 PM
snopercod's Avatar
I've flown with both a 3-blade Catto and a 2-blade Aymar-Deumth (also Great American). The vibration was much less with the 3-blade, but the takeoff performance was wimpy. Since I ordered a "cruise" prop, that was probably my fault. All I know is that I was only getting 2300 RPM on takeoff and it took me 4,000' to break ground on a hot day in Denver. The big difference was the glide performance. At best glide speed my rate of descent was 1,800 fpm with the 3-blade Catto and only 200 fpm with the two blade. I have video for the non-believers.
(2018 dues paid)
Old 09-11-2018, 08:35 PM
N49ex N49ex is offline
Default Hartzell 2 blade v.s.3 blade
I originally had a F7666-2 commonly used prop on an I/O-360 and replaced it with a 3 blade Hartzell scimitar prop. While the general wisdom is a 2 blade being faster than a 3 blade, my experience was the 3 blade climbs better AND achieves the same cruise speed. I attribute that ideal performance find to the improved design of the scimitar blades.
Reinhard Metz
Old 09-13-2018, 11:10 PM
charosenz's Avatar
charosenz charosenz is offline
Thanks for sharing that is fascinating.
What was the diameter of the 2 blade and 3 blade props?
Old 09-14-2018, 11:19 AM
snopercod's Avatar
Both were 62". The Lancair is so close to the ground that it requires a smaller prop. I still only have 7" clearance. The Catto 3-blade was a 62x76 and the two blade props were 62x75. I'm running the Great American 62x75 now. It's old and beat up but it really works well with my 140 HP high-compression O-290-D2. I see 2,300 rpm on takeoff vs. 2,140 with the Catto 3-blade.
(2018 dues paid)
Old 09-14-2018, 01:05 PM
Raymo's Avatar
Raymo Raymo is offline
Keep in mind that Snopercod is flying a Lancair so a direct comparison might not be appropriate. The Lancairs are very fast but also need higher speeds for takeoff and landing, due to the laminar flow wings.
I have a 3 blade Catto and spin ~2300 on take-off roll and off the ground in around 600 feet. I generally climb around 115-120 KIAS. Very smooth operation.
Ray
O-360-A4M w/ AFP FM-150 FI, 1 PMag, Vetterman Trombone Exh, SkyTech starter, PlanePower Alt
All lines by TSFlightLines
NSDQ
Old 09-14-2018, 02:40 PM
snopercod's Avatar
For the record, My Lancair breaks ground at 65-70 KIAS and lands at 75-80 KIAS. I am convinced the reason my takeoff performance was so wimpy with the Catto 3-blade was that I told Nicole that I wanted a "cruise prop" and that's what they made for me. It worked great at cruise, especially up in the low teens.
(2018 dues paid)
Old 09-14-2018, 03:25 PM
Greg Arehart's Avatar
Greg Arehart Greg Arehart is offline
A bit late getting back to you on the diameters. Sensenich was 72" diameter and Catto is 68" so I gained 2" of clearance. Seems like a lot more than that. Both of mine are pitched for cruise and turn around 2250 max near SL. I still have no issues getting off the ground and climbing. The other day (solo) I took off at around 9000 DA and was seeing 2100 fpm on climbout. Not bad for a cruise prop!
Greg
Greg Arehart
RV-9B (Big tires) Tipup @AJZ or CYSQ
N 7965A
Old 09-15-2018, 12:14 AM
charosenz's Avatar
Greg
Greg,
I really appreciate the follow up thank you.
Old 09-15-2018, 12:16 AM
charosenz's Avatar
Thanks to both of you, great info, very helpful.
Charlie
