Go Back   VAF Forums > RV Firewall Forward Section > Propellers
Old 09-10-2018, 12:21 AM
charosenz's Avatar
charosenz charosenz is offline
Default 2 blade vs 3 blade. Ever tried both?
I know the general concept (all things equal) is that a 2 blade is generally considered "faster" and a 3 blade a better climb performance prop.
I would appreciate hearing from guys who have actual experience trying both a 2 blade prop and a 3 blade prop on the same plane and how they compared.
Thanks.
Charlie.
Old 09-10-2018, 06:12 AM
N941WR's Avatar
N941WR N941WR is offline
Thanks.
Charlie.
It depends.
If you are talking about one size fits all store bought props, you are correct.
If you are talking about custom cut props like a Cato, they.can be cut so they have equal performance. It all depends on what you order.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 09-10-2018, 08:38 AM
Default Data please
I would like to see the hard data on a fixed pitch prop being equivalent to a c/s prop. Call it engineering curiosity...or skepticism...
Bob
Aerospace Engineer '88
Structure - 90% Done
Cabin Top - Aaarrghhh...
EFII System 32 - Done
290 HP Barrett Hung
Wiring...
Dues Paid 2018,...Thanks DR+
Old 09-10-2018, 09:05 AM
Masterplumber Masterplumber is offline
My first RV was a 7A that had a three blade MT prop. I sold that and then built an RV10 with a two blade prop. Both have been nice aircraft. I've put about 500 hours on each of them.
I think the 7A was a bit slow and I agree with the notion about top speed being slower. It was a good prop though and I was pleased with it.
The RV 10 performs nicely and I am happy with it also.
I liked the three blade because I liked the way it looked and of course the MT quality. However, it was really a pain to take off the lower cowl with the third blade.
The two blade performs a little better (I think) and I find cowl removal a lot easier now. Climb is not an issue for me, though the three blade may be better in that regard. I don't know, both aircraft could climb very well.
I would choose a two blade if I needed another prop, all things considered. Of course, YMMV.
John Koonce
N78MU
Old 09-10-2018, 02:57 PM
db1yg's Avatar
db1yg db1yg is offline
Default 2 Blade vs 3 Blade
Hi Charlie,
I have done just that using Catto products. Do a search for:
2 Blade Catto vs 3 Blade Catto
My post is #15.
Hope this helps.
db
Dave B.
RV9a/ECiIO360/James Cowl/WW RV200 Prop
Flying since 3/06 and still smiling!!!
Old 09-10-2018, 04:50 PM
Greg Arehart's Avatar
Greg Arehart Greg Arehart is offline
RV-9 with standard Sensenich aluminum prop vs. 3-blade Catto. Both have similar top speeds at 8500' DA (within measurement error). Both get me off the ground in about the same distance. I did not do specific climb tests, but don't think there was a lot of difference in climb performance. 3-blade is definitely smoother-running. And there is distinctly a weight/CG difference (42 lb for the aluminum prop vs. 14 for the Catto). 3-blade has more ground clearance, especially good if you are operating from non-paved strips.
That's my experience.
Greg
Greg Arehart
RV-9B (Big tires) Tipup @AJZ or CYSQ
N 7965A
Old 09-10-2018, 08:47 PM
charosenz's Avatar
Originally Posted by db1yg View Post
Hi Charlie,
My post is #15.
Hope this helps.
db
I will thanks!
Old 09-10-2018, 08:48 PM
charosenz's Avatar
Greg
Greg what were the diameter of each prop. I.E. how much clearance did/do you gain switching to a 3 bladed prop?
Old 09-10-2018, 09:57 PM
sirlegin's Avatar
sirlegin sirlegin is offline
Finger nail polish takes care of the scratches. 3 blade Catto are cool and effective
Nigel
RV9A-N113SQ
52F
Old 09-10-2018, 11:21 PM
charosenz's Avatar
Hi Charlie,
My post is #15.
Hope this helps.
db
Great thread thanks for that tip....
Charlie
