Old 09-08-2018, 08:32 PM
mturnerb mturnerb is offline
Default Beringer brakes installation - photos
Does anyone have photos of completed installation of Beringer brakes on RV14A? Particularly interested in connections at the gear leg/wheel
Thanks in advance..
Turner Billingsley
RV-14A In Progress
N14VB Reserved
Old 09-09-2018, 12:23 AM
Av8rRob's Avatar
Av8rRob Av8rRob is offline
Heres mine.
http://av8rrob.blogspot.com/2017/07/...e-install.html
Rob Lasater
Rv-14 still workin
Paid nov 2018
Old 09-09-2018, 06:30 AM
Originally Posted by Av8rRob View Post
Thanks. I should have been more specific - looking for photos of the installation on the gear legs and connection of the brake lines on the wheels.
Turner Billingsley
RV-14A In Progress
N14VB Reserved
Old 09-09-2018, 06:41 AM
MED MED is offline
Maybe these will help.
MED
140236
N435MD
Old 09-09-2018, 08:52 AM
Hey Rob---how are you going to get to the ALIR valve to adjust the brake bias? You have along longer arms than I have!
Tom
Ridgeland, SC
Old 09-09-2018, 08:53 AM
Turner---sent you some pics
Tom
Ridgeland, SC
Old 09-09-2018, 09:57 AM
Av8rRob's Avatar
Tom
You are right, it is tucked way under there. My understanding is once this is set, you dont mess with it. So my theory was keep it close with the shortest run of hose. When I start to use is after the break in period it will be a pain for the 1st few adjustments then leave it alone.
Rob Lasater
Rv-14 still workin
Paid nov 2018
Old 09-09-2018, 10:58 AM
Thanks - I also got some photos from Tom. Great community!
Turner Billingsley
RV-14A In Progress
N14VB Reserved
Old 11-19-2018, 10:16 PM
Aircraft Specialty Aircraft Specialty is offline
To add to the pictures, here is how we do the Beringer 14A Gear Leg Hoses.
Here is how we do the Beringer tailwheel gear leg hoses
Steve Tschurwald- Aircraft Specialty LLC (Your source for Custom Parts for Experimental Aircraft), AS FLIGHTLINES (Joint Venture with TS Flightlines)
aircraftspecialty@gmail.com
www.aircraftspecialty.com
Old 12-30-2018, 01:36 AM
We have been hard at work beta testing multiple Beringer cabin and gear hose configurations over the past several months. In addition, we now have a dealership agreement with Beringer that allows us to sell the COMPLETE Beringer kits directly to our customers. This allows us to omit the "do it yourself" brake line components that come standard with normal Beringer purchases. We are able to pass along these savings to our customers.
At the moment, we have tested the RV14 TW cabin brake lines in the Standard, Parking Brake, and PB/ALIR Valve configurations. We also have tested the Beringer gear leg hoses on both the 14/14A.
We have enough 14A data to interpolate the line length change for the cabin hoses that are different from the TW. However, we would like to get some good installation pictures for a 14A and therefore will be offering a beta testing discount to the first 2 14A installers.
Thanks again to everyone for your help in developing and perfecting the lengths on these packages.
Have fun building!!!
Steve and Tom (Aircraft Specialty Flightlines)
P.S. We have a lot of new and exciting things happening in 2019 and look forward to continuing to work with all of you to make these incredible flying machines even a bit more personalized.
