Old 09-08-2018, 11:00 AM
galt1074 galt1074 is offline
Default Engine question
I need a little advice on engines. To be honest, I'm probably way to early in the process to be thinking about this but this feels like too good an opportunity to pass up.
Is there anything I need to think about before buying an IO-360ES? I've got a chance to buy a brand new one, still in the crate for WELL below market price.
Greg
Greg LeCrone
Lakenheath, UK
Builder 74755
RV-7: Just started empennage
Old 09-08-2018, 11:45 AM
Mel's Avatar
Mel Mel is online now
Greg
Well the biggest concern for me would be that I believe that the IO-360-ES is a 6 cylinder Continental and would not be well suited for an RV-7.
A&P/EAA Tech Counselor/Flight Advisor/Nat'l Test Pilot School
<rvmel(at)icloud.com>
North Texas (8TA5)
Legend Cub purchased 12/2017
FRIEND of the RV-1
Eagle's Nest Mentor
Old 09-08-2018, 12:06 PM
Default size
Mel,
That is my concern. Understanding total displacement is the same, I don't know if the dimensions of the engine increase to the point that it won't fit in the cowl anymore.
There are certainly enough engine options to make one's head spin before you even start considering spinning a prop.
Greg
Greg LeCrone
Lakenheath, UK
Builder 74755
Old 09-08-2018, 12:13 PM
Mel's Avatar
Mel,
Greg
Besides size, the Continental is quite heavy.
North Texas (8TA5)
FRIEND of the RV-1
Eagle's Nest Mentor
Old 09-08-2018, 12:39 PM
Carl Froehlich's Avatar
Mel,
Greg
Greg,
To use a six cylinder Continental engine you need to rethink your build. Every aspect of Vanís firewall forward support would be gone. In short, you would start with this engine and build the airplane around it. You would weld up your own custom engine mount, weld up custom exhaust, redo most of the cowl, etc.
Vanís assumes the builder uses the recommended engine, down to the specific configuration. If you follow these guidelines you will have some assurance that stuff will fit. Vanís cannot support every permutation of engine and engine accessories that a builder might select.
Old 09-08-2018, 01:56 PM
Default Thank you
Thank you both for the excellent advice. Obviously not the engine I should be looking at.
I'm so early in the build process and I'm already gaining so much from these forums.
You guys are awesome
Greg
Greg LeCrone
Lakenheath, UK
Builder 74755
