Old 09-08-2018, 05:23 AM
OrenAir OrenAir is offline
Default Math problem?
In the horizontal stab attach bar, page 10-04, I'm having math trouble.
The top left figure says the piece is 5 and 13/16 wide. The bottom says it's the sum of 1 and 3/16, 1 and 1/4, 1, 1 and 1/4, and 1 and 3/16. I add those up and get 5 and 14/16.
Millimeters don't work for me either. Top view says 147.6 mm. Bottom says sum of 29.8, 31.8, 25.3, 31.8 and 29.8. My calculator says that's 148.5.
What mistake did I make? Is it the difference because the back side is angled, and the top is measuring the back while the bottom is measuring the front?
Old 09-08-2018, 05:42 AM
mturnerb mturnerb is offline
I think your math is correct but it's pretty hard to be that precise when making this part. I started from the center and used the template as drawn as a guide. (comparing my marks on part to drawing as well as the part as I took material away to get to the final version). It came out "close enough".
You're talking about 1/32" on each side of center difference on a hand made part. If you could get it that precise, I'd say err on the side of caution and spot Van's the 1/32" - make the top of the bar 1/32" wider on each side.
Turner Billingsley
RV-14A In Progress
N14VB Reserved
Old 09-08-2018, 06:28 AM
What piece does it connect with? I want to make sure it fits great before riveting.
Old 09-08-2018, 06:46 AM
Reflex Reflex is offline
It rivets to F-01411E and F-01414 which rivets to the main side longeron (page 10-27 figure 1). The "3-sided notch" or cut out is so that the bolts that hold on the elevator bearing (page 8-03 figure 2) will clear.
If the piece is too long, it will stick out over the F-01414 deck. Not a big deal as you'd never see it. However, the 5 13/16 measurement works perfectly. If you're +/- 1/32", you'll be fine.
Dues Paid for 2019
RV-14
Empennage Complete
Getting Ready to Close Wings
Old 09-08-2018, 07:09 AM
All the rivet holes are already in the piece. Clearance is not that critical (having already built this part and test fitted the HS) - if within 1/32" no issue at all.
Turner Billingsley
RV-14A In Progress
N14VB Reserved
Old 09-08-2018, 09:13 AM
Awesome. Thanks for your help. :-)
Old 09-08-2018, 03:20 PM
StressedOut StressedOut is offline
Slightly off topic, but still related. I am not a fan of fractional dimensions. It's easier to make math mistakes. I wish Vans would stop using them and go to decimal.
I have a friend who occasionally helps on my build who also happens to be a machinist with his own milling machine. He is going to put the F-01411D on his milling machine and CNC machine it down to final dimensions.
Art Jackson
RV-14A Kit#140433, N393AJ Reserved
Completed: Vertical Stab/Horizontal Stab
Scrapped: Rudder
Working on: Empennage (Elevator)
Construction log - mykitlog.com/ajackson
Dues paid on 10 October 2018
Member of EAA Chapter 92 (KCNO)
Pet peeve: "Lose" (rhymes with "booze") is the opposite of "find". "Loose" (rhymes with "juice") means "not tight".
Old 09-08-2018, 06:16 PM
RV-14E's Avatar
RV-14E RV-14E is offline
Excellent catch!
As long as you follow the taper of the aft deck, I suspect you'll be fine.
Do your best and go to town.
E
http://rv-14a.blogspot.com/
