POSTING RULES
Donate yearly (please).
Advertise in here!
Today's Posts
Insert Pics
09-07-2018, 06:25 PM
Screw/Bolt Hole?
Anyone know whats supposed to go in this hole, both sides of the fuselage, just below the fwd fuel tank attach of the RV-7?
I've looked at a number of drawings where I would think the info should be but, keep coming up empty.
Steven Hild
Rio Communities, NM USA
RV-7, FWF/Fiberglass, N590SC res
Contributing annually since January 2002
09-07-2018, 06:37 PM
Per drawings 28 section C-10, it's called out as a 426AD4-6 rivet.
Carlos in Arizona
EAA Chapter 538 President, www.538.eaachapter.org
Wittman Tailwind W8 N53CH (built & sold)
Pazmany PL-1 N2029 (bought & sold)
RV7 - N537TC (reserved & building)
Emp, Wings & Fuse done - working on FWF
"The air is an extremely dangerous, jealous and exacting mistress. Once under the spell most lovers are faithful to the end, which is not always old age." - Winston Churchill
09-07-2018, 06:43 PM
I have to disagree with Carlos.
Have a look at DWG 38, Detail F.
It's the lower screw of the reinforcement angle (F-786B) that binds the bracket to the lower and auxiliary longeron. I assume it's pretty critical screw.
Its a AN509 10R12 screw and you need to countersink.
Reason: Added picture
09-07-2018, 06:49 PM
I should add it's a #10 sized hole, always has been, undrilled/enlarged.
Steven Hild
09-07-2018, 06:53 PM
BJorn is correct. You can see in my pic is says to look at DWG 23 and 38. I missed the detail in my search today.
Carlos in Arizona
Bjorn, you are correct, I now see it on the drawing you said.
Many Thanks!!
Steven Hild
Thread Tools |
Search this Thread |
Display Modes |
Linear Mode
