Old 09-09-2018, 02:45 PM
NewbRVator NewbRVator is offline
What's the difference between Lycoming's DEL120 and this type of powerplant?
https://www.lycoming.com/engines/del-120
Old 09-09-2018, 03:31 PM
rongawer rongawer is offline
The DEL120 is a four stroke compression ignition diesel.
The Higgs is a stepped cycle, spark ignition engine.
Ron Gawer
- RV10, N1530G (reserved). Build in progress.
- RV12, N975G, "The Commuter"
Old 09-09-2018, 04:35 PM
This seems very promising especially for the RV-10
Yearly dues paid 9/18
Old 09-09-2018, 04:55 PM
Default Yes...
Yes, sure looks like a good fit...
BUT
So did the Deltahawk, 6 Cylinder Pmags, The Dynacam, several small turboprops, etc.
Hopefully, this one will make it!
Bob
Aerospace Engineer '88
Structure - 90% Done
Cabin Top - Aaarrghhh...
EFII System 32 - Done
290 HP Barrett Hung
Wiring...
Dues Paid 2018,...Thanks DR+
Old 09-09-2018, 08:14 PM
Mudfly Mudfly is offline
....and the RV-14??
Good to see more and more of these new engine developments that don't use 100LL. I still have a hard time understanding all time and money being spent on trying to develop a "special fuel" for existing aircraft engines. Spend that time and money on developing a new engine that burns Jet A, a fuel readily available world wide. We put a man on the moon...surely an engine for a small airplane can't be that difficult.
Good luck to these guys!
Shawn Edwards
RV-14A (140174)
www.myrv14build.blogspot.com
2019 VAF Donation Complete
Old 09-09-2018, 08:29 PM
Any engine will make plenty of torque if it's geared low enough.
For an existing airplane design, it suggests that an optimum prop would be fairly long. If so, that introduces ground clearance issues. Or it could have a large number of blades.
Old 09-09-2018, 10:15 PM
Default Itís all about the money
The problem is that the development costs are astronomical...and the potential market return is tiny. Putting a man on he moon cost about 14 billion dollars IN THE 60s. There were many thousands of people involved and it took the government to finance it. Designing and going to production on a small airplane engine, well, if the numbers were favorable there would be many more choices available now...
Bob
290 HP Barrett Hung
Wiring...
Old 09-10-2018, 09:28 PM
The prop currently be proposed is the MT-5. Itís a 5 bladed composite, but will handle the pulses. It weighs in at ~85#, so not bad. Should be smooth.
Ron Gawer
Old 09-10-2018, 10:05 PM
Default Prop
85 lbs for the prop? Thats about 30 lbs more than my MTV9 which is 12 lbs more than the recommended MTV12. That weight out on the nose of the -10 may be an issue...
Bob
290 HP Barrett Hung
Wiring...
Old 09-11-2018, 03:57 AM
rmartingt's Avatar
rmartingt rmartingt is offline
Originally Posted by Mudfly View Post
....and the RV-14??
Itís not a question of ďis it possibleĒ, itís a question of ďcan we afford itĒ. A brand new engine that can slot into place where a Lycoming went but burns Jet wonít be cheap to develop, and even if every light airplane in the US bought one youíd only be looking at 160k or so units to amortize all that development expense across. My guess is that the final experimental version would run about what a new Lycoming does. And thatís not even accounting for certification costs, which would probably add 50% to the development cost, and then another 20-30% for the STCs required.
Most of the GA fleet is not going to drop money equivalent to 1-3 times the current value of their aircraft on a new engine.
By contrast, a 100LL replacement is expensive to develop too, but its sales are in much smaller and affordable units over a longer time. Itís easier for the fleet to absorb a 20-30% increase in fuel costs than capital outlay exceeding the aircraftís hull value.
RV-7ER - canoe flipped
There are two kinds of fool in the world. The first says "this is old, and therefore good"; the second says "this is new, and therefore better".
