Old 09-07-2018, 05:28 PM
rongawer rongawer is offline
Default AC Aero Engines
Hey folks, have you seen these? Pretty sexy looking.
http://www.ac-aero.com/jet-a/
Compression ignition V4 that weighs 137kg dry weight and makes ~350 hp, and a train engine's worth of torque (>650 ft-lbs at the prop). Looks like fun.
I've been communicating with them and thinking about this for my RV10.
Ron Gawer
- RV10, N1530G (reserved). Build in progress.
- RV12, N975G, "The Commuter"
Old 09-07-2018, 05:43 PM
Erimo's Avatar
Erimo Erimo is offline
About reliability ?
Eric
RV 14A - #140252 - Flying
France
2018 dues paid
Old 09-07-2018, 07:00 PM
OkieDave OkieDave is offline
What engine speed do you need to make that much power? That looks kinda like a gearbox up front.
Old 09-07-2018, 09:33 PM
majuro15's Avatar
majuro15 majuro15 is offline
Ron, I sent you a PM. Give me a call.
Tim
www.N1017H.com
Tim Huneycutt, Capt, NCANG
RV-10 Finish kit under construction
N1017H Reserved
EAA #: 1106970
2019 VAF Dues Paid!
Old 09-08-2018, 07:24 AM
F1R F1R is offline
Default ANY PIREPS on the AX 50 cylinders?
Does anybody other than Kevin Eldridge have experience with the AX 50 cylinders on Lycomings yet?
Old 09-08-2018, 09:03 AM
Default Cylinders
I was going to use these on my -10 but, at the time, they were made of Unobtainium...
Bob
Aerospace Engineer '88
Structure - 90% Done
Cabin Top - Aaarrghhh...
EFII System 32 - Done
290 HP Barrett Hung
Wiring...
Dues Paid 2018,...Thanks DR+
Old 09-08-2018, 12:17 PM
airguy's Avatar
airguy airguy is offline
Compression ignition? Certainly looks like a pair of spark plugs on each cylinder...
Greg Niehues - PPSEL, IFR, Repairman Cert.
Garden City, TX VAF 2019 dues paid
N16GN flying 380hrs and counting! Built an off-plan 9A with too much fuel and too much HP. Should drop dead any minute now.
Old 09-08-2018, 12:27 PM
Default Um...
It looks to be a "combined cycle" engine. Reading the literature, it seems to be a two stroke engine that burns jet A. I didn't see anything that said it was a compression ignition engine...though I may have missed it...
Bob
290 HP Barrett Hung
Wiring...
Old 09-09-2018, 10:23 AM
It's a It is a stepped diesel which uses a spark plug for ignition and has dual plugs for redundancy. I understand they have prototypes in operation, but nothing in production yet. The design is actually over 100 years old, but his use of an integral gearbox and cooling jackets are innovative. I hope he makes it to production. It would be a very torquey engine, efficient in a lightweight package.
Ron Gawer
Old 09-09-2018, 10:54 AM
Default Interesting
Interesting concept...been around for a long time. I hope he makes it work...
Bob
290 HP Barrett Hung
Wiring...
