Old 09-06-2018, 06:39 PM
bomber_JB bomber_JB is offline
Default RV-10 Cabin lights
We've decided everything electrical for our RV-10 except how many and what kind of cabin lights we should plan for. Initial thoughts are some kind of map/reading light for each of the four seats, a dome light and a light for the baggage compartment.
Would appreciate some ideas from builders on what they have installed. Pictures or model numbers of lights will help.
Maybe there are some stick-on LED lights that are battery powered? Would not have to supply aircraft power to them.
Jerry
Old 09-06-2018, 06:42 PM
At least for now, LED flashlights are my planned go-to. If I find the lack of overhead lights to be an issue, running wires and adding lights isn't a big deal.
Kyle Boatright
Atlanta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 09-07-2018, 05:25 AM
Electrogunner Electrogunner is offline
Default Lights
Check out pilotlights.net
RV10 N620RV
IO540 C4B5
Whirlwind 375HRT
Garmin G900X
First Flight 2/14/2019
Old 09-07-2018, 05:38 AM
rleffler's Avatar
rleffler rleffler is offline
I've got three types of lighting in my overhead.
  1. Directional blue lights to wash the panel
  2. Directional blue lights that is aimed at the lap of both front seats for map reading
  3. Multiple white lights used to load the aircraft at night
After five years, I can't recall ever using the first two types in flight. I've only used the white lights on the ground. There is enough light off my screens that the cockpit is fairly well illuminated.
Take a look at the lights that Stein offers.
Bob Leffler
N410BL - RV10 Flying
http://mykitlog.com/rleffler
Old 09-07-2018, 06:54 AM
AviatorJ AviatorJ is offline
Funny the little things I got hung up on during this build. Overhead lights were one of those things. With a full glass panel and lighted switches I didn't feel the need for glare shield lights. The only non-lighted switches are the batteries and alternators. Pretty easy to feel out and with the glass will actually be able to see them.
I still wanted white cabin lights for night time loading and unloading. But I also wanted some type in-flight night lighting if need be. There are some studies out there about which color is the best for retaining night vision. The jist I got from it is that it really doesn't matter if it's a greenish-blue, low intensity white or the tradition red we all know. I did however decide to go with red.
Here is my set up-
Have it actually installed now and I like it. I got these all from https://www.pilotlights.net/
Justin
RV-10, N10JW
http://operationrv10.blogspot.com/
Old 09-07-2018, 07:42 AM
Carl Froehlich's Avatar
Here is a $10 do it yourself overhead LED lights solution. The lights started life as a Harbor Freight battery clip on unit. The battery holder and mounting clip were cut off. I replaced the LEDs with some from Super Bright LEDs (at a few pennies each they are fun to play with).
Both lights are on a dimmer. This simple set up works amazingly well.
Old 09-07-2018, 08:37 AM
Not in an RV10... but I wanted lighting that was independent of the aircraft electrical system. Ended up buying inexpensive ($5) LED flashlights at WalMart. They feature a push-button on/off switch at one end and a fixed-focus head. They are installed using Adel clamps around the round body of the flashlight which provides for considerable flexibility in aiming angle.
For something so small and cheap I'm amazed at how often I use them since they provide light in the cockpit without having to turn on the Master. Great for writing down notes about the flight after you've shut down on a dark night, or for finding that one thing you misplaced as you're loading the airplane.
Old 09-07-2018, 01:36 PM
togaflyer togaflyer is offline
Check out “pilotlights.net” They have a good selection of led light products. I do not have an overhead console, so I used an led down light, dome light. I trimed it so the light blends in with the cabin top center support. It has both white and red led lights incorporated. I also used the mini gooseneck lamps with red leds. Mounted one each on the far right and left side of the panel.
Old 09-07-2018, 08:38 PM
majuro15's Avatar
majuro15 majuro15 is offline
Sean at planearound.com has his LED's back in stock and they are great quality. I had one board that was bad and he sent out a new one ASAP. I used three of those, front seats, rear seats, and baggage area. Then, each seat has an Aveo Eyebeam touch for task lighting. I also added some super cheap flush footwell lights from ACS.
www.N1017H.com
Tim Huneycutt, Capt, NCANG
RV-10 Powered on!
N1017H Reserved
EAA #: 1106970
2019 VAF Dues Paid!
Old 09-08-2018, 12:22 AM
az_gila's Avatar
az_gila az_gila is offline
Smile
I was thinking of something completely flush for an aft overhead light in the overhead console.
One of these -
http://www.mpja.com/24-3X8-Piranah-L...info/33069+OP/
- set behind a piece of milky white Plexiglas.
I'm going to experiment with this idea.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
