Old 09-06-2018, 07:00 PM
didja didja is offline
Default Looks like two of the same part?
I have emailed van's already (they were closed already when I discovered this), but am wanting to just make sure that I am not wrong in what I believe to be the problem.....
I am currently working on the rear spar for the right wing. This is the first wing I started on (haven't touched the left wing yet). As I went to get the rear spar, I pulled the two parts apart from their shipping tape and after looking at it closer, it appears that the two parts are both for the left wing. One is labeled W-00007A-L and the other is labeled W-00007-R, but when put side by side, they appear to both definitely be of the left influence.....
I am hoping that the pictures I took will attach correctly, but if you look, the first picture shows the two labels (the one from what is supposed to be the right spar has been removed, but I put it back just to show reference and to show the label. You can see that the bluing matches the holes in the spar). It shows that they are labeled left and Right.
If you look at the second picture, it shows where the reinforcement fork attaches and they are both on the same side, with the flanges orientated the same (with the aft facing flange on top and the forward facing flange on bottom).
And if you look at the third picture, it shows where the outboard doubler attaches, again, on the same side and with the flanges both orientated the same way.
I just want to make sure that I am not missing something. Its not usual for Van's to mislabel things like this in my experience so far. I just emailed them tonight so I am hoping to hear back tomorrow, but just wanted to see if I was wrong or not. Thanks
Scott Emerson
RV-14a Kit# 140432
Working on: Wings
Construction log: https://www.youtube.com/channel/UCaZ...Uv2rlQsHtdRmmg
Donation Paid (military)
Old 09-06-2018, 07:08 PM
kmbusse kmbusse is offline
I had the exact same thing happen a few months ago. Same part as yours. I looked at it for an hour thinking I was looking at it wrong, but it was 2 lefts, but one labelled right. Looks like they may have done a batch of lefts marked as right. They were quick to send out a correct spar, but a costly mistake for them with shipping a part that big.
Good luck.
Kerry
140457
Old 09-06-2018, 07:43 PM
Bgill Bgill is offline
Default Same here
Same exact part for me as well. I had 2 lefts - one marked as a right. I had already match drilled and cut the hole before I realized it. Vans was quick to send out replacements. I was real concerned that the replacement would not makeit w/o damage but it was crated in plywood very well. All good now..
Byron
RV-10 40253 N253RV Flying
RV-14 140466 In build - Wings
Douglas, GA
Old 09-06-2018, 08:10 PM
Ok, glad to know I'm not crazy! It was driving me crazy! I'm hoping to hear from them tomorrow with plans on when to expect the right part!
Scott Emerson
RV-14a Kit# 140432
Working on: Wings
Old 09-06-2018, 08:52 PM
Default Moving on...
The good thing is there is plenty of other things to do till new parts arrive.. The leading edges and fuel tanks occupy a fair amount of time.
Byron
Douglas, GA
Old 09-07-2018, 12:41 AM
Aluminum Aluminum is offline
Default not uncommon
Had similar mix-up in my tailcone kit, two R stiffeners instead of R/L. Mothership sent correct part next day.
Dan V
'91 Zodiac flying since 2013
RV-14A in progress
2019 dues worth every penny
Old 09-07-2018, 08:09 AM
kbalch's Avatar
kbalch kbalch is offline
Yep, that's two left rear spars. I received two left tank attach brackets, but Van's sent out the right one (both meanings of the phrase!) forthwith.
Ken
RV-8 N118KB (sold)
RV-14A #140494 (Fuselage in progress)
N114KB (reserved)
Old 09-07-2018, 09:25 AM
slngsht slngsht is offline
I built two left wings before I noticed.
Old 09-07-2018, 04:43 PM
Discus2b Discus2b is offline
Excessive aileron trim, right.
Sharp to notice.
Old 09-07-2018, 04:55 PM
hahaha!!!
I received an email from Erik at Van's and he was very helpful in getting this all straightened out!
I've always been impressed by Van's customer service and this is no exception!
Scott Emerson
RV-14a Kit# 140432
Working on: Wings
