Old 09-06-2018, 07:29 PM
Default Flox
When I did mine, I added some flox to the epoxy then thickened it slightly with Cabo. I think mine was about the consistency of applesauce. The syringe had no problem injecting it into the void.
Bob
Aerospace Engineer '88
Structure - 90% Done
Cabin Top - Aaarrghhh...
EFII System 32 - Done
290 HP Barrett Hung
Wiring...
Dues Paid 2018,...Thanks DR+
Old 09-06-2018, 10:22 PM
az_gila's Avatar
az_gila az_gila is offline
Thanks... that gives me something to aim for...
I got these at the local Woodworkers store... should be good for resin.
https://www.systemthree.com/products/epoxy-syringe
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 09-07-2018, 06:40 PM
az_gila's Avatar
Thumbs up It worked
Thanks guys - the apple sauce epoxy with a 50-50 cabosil/flox additive worked great.
I put in over 10 cc and I could see it spreading out in all directions from the hole I put in the center of the 4 bolt hinge hole pattern. The excess epoxy made a nice fillet at the edges of the flat hinge area.
Gil Alexander
Old 09-07-2018, 09:35 PM
majuro15's Avatar
majuro15 majuro15 is offline
Good to hear. I have to do that around the door handle inset area on both doors. I got a good bond elsewhere, but couldn't really find a way to clamp that area.
www.N1017H.com
Tim Huneycutt, Capt, NCANG
RV-10 Finish kit under construction
N1017H Reserved
EAA #: 1106970
2019 VAF Dues Paid!
Old 09-08-2018, 01:15 AM
az_gila's Avatar
Smile
I'm not sure how the flashlight through the material idea would work with either the pink doors or the later grey gelcoat doors.
It is OK on the older green doors.
Gil Alexander
Old 09-08-2018, 07:57 AM
Kyle Boatright Kyle Boatright is online now
I can't see it working at all with the pink doors.
Kyle Boatright
Atlanta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 09-08-2018, 09:02 AM
Default Flashlight
I'm not sure how the flashlight would work but I used my LED trouble light behind the pink glass and it works just fine...
Bob
290 HP Barrett Hung
Wiring...
