Old 09-06-2018, 12:15 PM
Bavafa Bavafa is offline
Default Tail pipe tunnel
Just wondering folks who have painted their 14, if they have painted the tail pipe area/tunnel or leaving it unpainted. I am wondering if the heat will affect the paint. Mine is going to be a base/clear type paint. Would paint also adhere well to the stainless steel part. To make things more complicated for myself, I have extended some of the aluminum sheet to this area which was used for covering the end/corners of stainless steel sheet that covered the Fiberfax on the FW. I can remove it if I have to, if this area is to be painted.
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - Flying
Dues paid
Old 09-06-2018, 12:26 PM
JTJones's Avatar
JTJones JTJones is offline
Default Didn’t paint
I did not paint mine.
Jeffrey T Jones
RV-14 N588TJ Completed
First Flight July 10, 2018
Flight testing completed August 14, 2018
VAF dues paid plus beer money😜
Old 09-06-2018, 03:10 PM
n982sx n982sx is offline
Left mine unpainted as well.
Bob Meyers
Built and Flying RV-14A N626KM SN 140093 http://n626km.com
Built and Flying Sonex N982SX http://n982sx.com
Old 09-06-2018, 03:16 PM
Discus2b Discus2b is offline
negative..
Old 09-06-2018, 04:54 PM
Bootscooter's Avatar
Bootscooter Bootscooter is offline
Unpainted. I should imagine if you did paint it, it wouldn’t be long before it is stained from the heat.
Chad Boot
RV8 Empennage in progress
RV14 140331 VH-VNX. Flying/Sold
RV10 Standard Fuselage Complete
RV10 Empennage complete
RV-7 Slider Flying VH-VNZ
Sports Aircraft Assn Australia. Tech Councillor.
2019 Dues Paid
Old 09-06-2018, 05:43 PM
Nova RV Nova RV is offline
Painted my tunnel but I'm using the Vetterman exhaust with dual pipes that exit forward of the tunnel
Chris Moon
Leesburg, VA
RV-14A kit # 140243 (flying as of 11/18)
VAF 2018 and 2019 paid
www.mykitlog.com/chrismoon/
Old 09-06-2018, 06:32 PM
Thank you all for responding. I guess I will have mine unpainted. It is not visible but could create more issue if the heat affects it.
Mehrdad
Dues paid
Old 09-06-2018, 06:36 PM
Ron B. Ron B. is offline
I also covered mine with Fiberfax and S.S. foil. I did not paint the strips that finish off the edges and I think I used something like ".050 SS strips for that (short memory) . I've got just over 100 hrs on mine and I was washing the bottom of my plane today and was just inspecting this installation to see how it is staying in place. So far it looks just as it did when I installed it. Unless you look up into the hole you do not see the unpainted as the strips do not protrude under the fuselage over the bottom skin, just right up to it.I'm happy.
Thanks Ron
RV-10 SOLD
RV-14 Flying
