Old 09-06-2018, 09:47 AM
X747 X747 is offline
Default RV-10 Carb Heat
Any suggestions for adding a carb heat to an aspirated O540. The alternate air door intake source may provide adequate heat from the interior cowling where a carb heat box is not necessary.
Old 09-06-2018, 10:18 AM
Mousse Mousse is offline
Carb heat = YES
Alt. Air Door = Not necessary with carb heat installed.
The -10 is capable to fly at high altitude where you could need carb heat and cowling heat would not be hot enough.
My two cents.
Michel
Exempted but dues paid through 12/2019
RV-9 Sold
RV-10 Flying
Old 09-06-2018, 10:45 AM
Default Carb heat
You don't need to fly high to require carb heat...
Bob
Aerospace Engineer '88
Structure - 90% Done
Cabin Top - Aaarrghhh...
EFII System 32 - Done
290 HP Barrett Hung
Wiring...
Dues Paid 2018,...Thanks DR+
Old 09-06-2018, 10:57 AM
az_gila's Avatar
az_gila az_gila is offline
Exclamation
Yep... straight from the AOPA -
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
