Old 09-05-2018, 03:01 PM
steve murray's Avatar
steve murray steve murray is offline
Originally Posted by lr172 View Post
I agree with Bob, they should require similar current. You should understand that the external starter contactor that most use also requires "big boy" start switch, depending upon what you mean by "big boy." That ext contactor that most use draws almost 5 amps. Several start switches listed by ACS fall well short of that rating. I have no idea of the rating of the key switches, as I don't use them.
To the OP, note that you will still need a flyback diode to protect the switch, even if you skip the ext contactor.
I am familiar with putting diodes on the battery master solenoid. If I decide to only use the internal solenoid on the Skytec 149-NL starter, where would I put the diode?
Also, I am picking up the internal solenoid will draw about 5 on the activation line??? This seems high as I thought the battery masters only had a draw of about 1 amp (I may be confusing transient current flow vs steady state?) Please keep the advice coming, I am limited on my EE skills.
Steve
RV8 Flying since 2007
RV10 in construction (Finish Kit)
Old 09-06-2018, 09:15 AM
rocketbob's Avatar
rocketbob rocketbob is offline
Ideally the diode should be as close to the master solenoid as possible. In this case that's not practical so installing it on the switch will work fine.
Bob Japundza CFI A&PIA
N55BC RV-6 borrowed, flying
N678X F1 Rocket, under const.
N244BJ RV-6 "victim of SNF tornado" 1200+ hrs, rebuilding
N8155F C150 flying
N7925P PA-24-250 Comanche, restoring
Not a thing I own is stock.
