Old 09-04-2018, 04:45 PM
localizer localizer is offline
Default Are there rear bench seats for RV-10?
Hi,
Does anyone make rear bench seat for RV-10?
I'm not looking to add seats, just wondering if there is a bench available...
Thanks!
Yuri
DA40
RV-10 - build in progress
Old 09-04-2018, 04:55 PM
The center ‘tunnel’ is structural, and higher than the standard seats. So a bench would have to be higher, compromising headroom; or involve some serious structural modification.
Edit. As noted below, this is wrong. I forgot I put a small console here.
Old 09-04-2018, 05:17 PM
Bill Boyd's Avatar
Default Um...
mine's not. Tunnel perfectly level with rear seat pans. If not trying to add a third rear seat position, the need for a middle rear seat person to straddle the tunnel with the feet is not a consideration. Looks to me like this could be easily done with a modified seat back (and I believe has been, many times).
This seat mod would close off the baggage area a little more completely. But why give up the ability to carry long-ish items in the baggage area extending forward between the rear seats?
Bill Boyd
Hop-Along Aerodrome (12VA)
Old 09-04-2018, 05:28 PM
TomSpencer46 TomSpencer46 is offline
Cleveland tool makes a 60/40 bench foam that will make it a bench. If you want to put three seat belts for three kids all less then 100# go for it. That is what is great in the experimental world.
RV-10 started 11/15 N90Vt
1947 Bonanza 25 years flying
Home field (Spencer) VT09
Old 09-04-2018, 05:56 PM
Thanks! I will call Cleaveland.
No, I'm not looking to add a third seat or seat belt. Just like to have a bench and full width back without the slot between them.
Yuri
DA40
Old 09-04-2018, 06:18 PM
DRMA DRMA is offline
I bought the Cleaveland back forms which fill the center and provide rear headrests that match the front seats, and had them shipped to Oregon Aero. They upholstered the backs after attaching the center to one side, and created a bottom that is in essence a bench seat. If access is needed to the baggage area for a long item, one of the backs can be removed using the Vans standard hinge mount to allow this.
Oregon Aero did a beautiful job on the upholstery of the front and back seats for me!
Dave Macdonald
RV-10 Finishing Kit & FWF in-progress
2019 VAF Dues Paid
Old 09-04-2018, 06:32 PM
Classic Aero used to produce such a seat-------perhaps if you ask them, they may make you one??
Old 09-04-2018, 07:08 PM
rdrcrmatt rdrcrmatt is online now
We have the South Florida Sport Aviation kit (Flyer), and it's not a bench, but certainly not 2 individual buckets.
Matt
CFI / RV-10
Old 09-05-2018, 01:20 AM
woxofswa woxofswa is offline
This was done by Abby at Flightline and we love it, but Iíve heard she doesnít do RV10 kits anymore.
Myron Nelson
Mesa, AZ
N24EV
RV-10 BPE, Dynon, Airflow systems A/C
First flight May 10, 2014
Old 09-05-2018, 05:32 AM
RV10Pilot RV10Pilot is offline
Not totally true. She does not do side panels for the R10 anymore. Flightline will still do RV-10 seats and carpet.
It would not be difficult to roll your own modification for a rear bench seat. Either a middle insert, 60/40 split seat or a full back. Use the same construction technique in the plans and extend one of the sides or make a small insert section and attach it to floor with a piano hinge.
