Old 09-02-2018, 02:48 AM
HansLab HansLab is offline
Default Cotterpins on maingear
Hi all,
How in the World did you manage to get the cotter-pins in the main gear axle? They are too long to be able to be put in without bending severely, too thick to fit in properly when hold with a pliers and being damaged by that pliers a bit.
Is is permitted to put a slightly thinner pin in?
Hans Labruyere
build & sold project Kitfox IV
Bought project & building RV12 #120742
Old 09-02-2018, 07:11 AM
s24789 s24789 is offline
Line the holes in the axel with the nut. The reason there are holes on each flat of the nut is to give you options. Carefully tap the cotter key using a slotted screwdriver on the top of the key and hammer. It is tight but they will go thru. One of ours is always a pain, the other just drops in.
Kevin Phelps
Paid thru Dec19
RV-7A flying N782WP
Stuart, Fl
Old 09-02-2018, 07:12 AM
Sorry Habs I just saw you have a 12. We have a 7A.
Kevin Phelps
Paid thru Dec19
RV-7A flying N782WP
Stuart, Fl
Old 09-02-2018, 08:49 AM
John-G John-G is offline
Hans ---- Yep, the cotter-pins are longer than straight in access will allow. It is necessary to bend the cotter-pin a bit to create a slight crescent moon shape to allow the cotter-pin to clear the wheel enough to begin going into the hole in the axle.
John
www.dogaviation.com
Now Flying!!
Dues paid until September 2019
Old 09-02-2018, 06:25 PM
longline longline is offline
Default One solution
is to simply use TWO short cotter pins, one on each side. This assumes you have access to the inner diameter. Of course, this does not work with solid axels... Now that I think about it, my RV8 has solid axels... whoops!
Old 09-07-2018, 10:47 AM
Charlie12 Charlie12 is offline
Maybe I shouldn't reply without going to my hangar to look. But after the crescent moon bending process to get the first set in, I think I was able to just shorten the cotter pin with wire cutters so that it would fit inside the wheel. Length of the cotter pin is not critical as long as enough sticks out to bend it over for retention.
RV-12 #120768, first flight Sept. 2016
180 hrs as of 1/1/2019
