Old 08-31-2018, 10:16 AM
SgtZim SgtZim is offline
Default Caution when handling without the v stab installed
I was moving the plane around today after getting the main wheels installed, and dropped the tailwheel from a couple of inches as I was setting it back down. Vertical Stab was removed and the only thing holding the aft steel fitting to the last bulkhead WAS two an3 "keeper" rivets. (I forgot that)
So the rivets sheared off and the stinger made a small ding on the aft bulkhead and I have to put a buck in the swear jar.
So be sure to keep those 3 AN4 bolts in place if you have the tail off - which most folks do when transporting to the airport for assembly.
https://www.facebook.com/BZsRVprojec...type=3&theater
RV-8 slow build
IO360-M1B Sensenich fixed pitch
Garmin G3X
GTN 625
GNC 255
GTR 20
GTX 45R
G5 x 2
Facebook "log" https://www.facebook.com/BZsRVproject/
Old 09-09-2018, 05:15 AM
chopperchops chopperchops is offline
Default Good tip!
Thanks for that, I will certainly keep that in mind. I cannot afford for anything else to go wrong, swear jar is full, and outa cash!!!
Rob Chopin
QB RV8
Wings done, fuse in progress.
Queensland Australia
VAF Dues paid-worth every penny!!!
