Old 08-27-2018, 07:47 AM
Brantel's Avatar
Brantel Brantel is online now
Default RV-10 Pop Rivet Dimple Die Question
My old pop rivet dimple dies are shot and never worked well for my RV7. I have no idea what brand they are but they look like super cheap junk. They are all rusted up and not worth trying to save them.
That being said, I am either going to order some from ACS who claim they are old Avery stock or some from Cleveland.
The question is:
Are there any cases where you really need a 1/8" pop rivet dimple tool on the RV10? To be honest I don't remember ever using the 1/8" one on the 7 and have a hard time imagining anywhere you would need one on the 10???
I would like to spend that $25-$30 bucks somewhere else if I don't really need them.
Thanks!
Brian C.
Brantel (Brian Chesteen),
Check out my RV-10 builder's BLOG
RV-10, #41942, N?????, Working on Emp/Tail Cone
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Old 08-27-2018, 08:05 AM
Brian, I can't think of one.
That might be a tool to buy or borrow IF the need arises.
Kyle Boatright
Atlanta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 08-27-2018, 08:23 AM
lr172 lr172 is offline
I used the 3/32 die on a handful of occasions. I don't have an 1/8" I didn't have either on the 6, but used the rivet gun. I took an old air chisel bit (same shaft arrangement) and ground the end flat and put a hole in it for the die shaft. It works fine, but you need someone to hold a bucking bar on the opposite die.
N64LR
RV-10 in progress
Old 08-29-2018, 07:37 AM
echozulu echozulu is offline
Don't think you need one. My tool kit I got from Isham only came with a 3/32".
RV-10 - Empennage 90%
QB Fuse - Delivered
QB Wings - Delivered
Ocean City, MD
Old 08-29-2018, 07:58 AM
Paddy's Avatar
Paddy Paddy is offline
Default CS4-4 Rivets in Floor Pans
The floor pans in the -10 are installed with (a lot of) CS4-4 rivets.
RV-10 N415JS
Slow build kit #40874
Homebuilt Kit Champion Oshkosh 2019
Old 08-29-2018, 10:14 AM
Brantel's Avatar
Can you dimple them with a squeezer or C-frame/DRDT-2?
Old 08-29-2018, 10:22 AM
Yes you can.
Kyle Boatright
Atlanta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 09-04-2018, 11:25 AM
ppilotmike's Avatar
I got an Isham kit that came with the 3/32 pop-rivet dimple tool. Yes, you do use it in a couple locations. As I recall, I used them to dimple about 16-20 holes in my build so far (I'm working on the fiberglass top now, so pretty much done with metal work). Most of the use was while building the tail feathers, flaps and ailerons, and the rest was on the fuselage. Perhaps, if you go quick-built wings and fuse, then you won't need the tool except for on the tail kit. There are some other spots where I used the Cleveland close quarters dimpling tool, for skins and such, where I didn't want to pry open the metal to use my DRDT2 and the hole was too far away for the throat on my squeezer.
Mike Rettig
EAA Chapter 301 www.eaa301.org
VAF Dues Current: Paid for 2019 on 12/03/18
RV-10 Working on the "Dreaded Doors"
http://www.mykitlog.com/users/index....ig&project=803
https://www.youtube.com/watch?v=zKCyX2FXrlw
Old 09-06-2018, 09:56 AM
SeanM SeanM is offline
I really do not like the pop-rivet dimple tool. It doesn't dimple well and I can't find replacement nails that are compatible with it. I've bought every nail under the sun from lowes and home-depot. They're all either too big or too small. If you search the forums you'll see others that have had the same issue.
I gave up and threw mine away.
I've been able to get everything so far (currently working on fuel tanks) with drdt-2, squeezer, and this-
http://www.cleavelandtool.com/Tight-.../#.W5FLGuhKhaQ
And this was specifically helpful for about 20 or so holes on the wings (slow build)-
http://www.cleavelandtool.com/3_32-V.../#.W5FLLehKhaQ
Old 09-06-2018, 10:08 AM
Mel's Avatar
Mel Mel is offline
On the other hand, I've built 8 airplanes using nothing BUT the pop-rivet dimpler and vice-grip dimplers. Perfect dimples every time. Find the correct nail, use pneumatic puller, adjust air pressure up slowly until the dimple is perfect. I can do a complete wing panel with 2 or 3 nails.
I will also add that I made my on dies out of stainless. 3/32, 1/8, 5/32.
A&P/EAA (LifeTime) Tech Counselor/Flight Advisor/Nat'l Test Pilot School
<rvmel(at)icloud.com>
North Texas (8TA5)
RV-6 Flying since 1993, 172hp O-320, 3-Blade Catto (since 2003)Sold
Legend Cub purchased 12/2017
FRIEND of the RV-1
Eagle's Nest Mentor
