Old 08-26-2018, 01:05 PM
mmcmanus mmcmanus is offline
Default Need Condition Inspection Checklist
I need a condition inspection checklist. I found a few threads here with links to a checklist but the threads were old and the link no longer exists. I also checked Van's website and no joy. Any help would be appreciated. Post here or you can send to my email.
mmcmanus@sstelco.com
Thanks.
Matt
Old 08-26-2018, 02:04 PM
330drvr 330drvr is offline
I just sent mine via email
Bruce Brock
N174MR
RV-7A
IO-360
Dual GRT HX & Mini
Dual Adaptive AHARS
GNS 480 Navigator
Dues paid 2018
Old 08-26-2018, 03:42 PM
Default Checklist
Thank You. I got a couple that look great. I appreciate the quick response.
Matt McManus
RV7A
Old 08-26-2018, 04:59 PM
N941WR's Avatar
N941WR N941WR is offline
There are a couple listed on the bottom of the POH page.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 08-27-2018, 08:14 PM
dww1977 dww1977 is offline
I’m a new RV-7 owner in need of condition inspection checklist for RV7. Would appreciate you sending me the ones you received. Thanks!
Old 01-21-2019, 11:45 AM
schaplerrh schaplerrh is offline
I need one too, desperately! My regular mechanic can no longer work due to a serious injury so I'm going to use the local shop that has never worked on an RV7. It's a good shop, just no RV experience. Robert
Old 01-21-2019, 05:56 PM
Walt's Avatar
Walt Walt is offline
I have one posted on my website:
http://www.expaircraft.com/PDFgallery.htm
EXP Aircraft Services LLC
RV7A built 2004, 1700+ hrs
Old 01-22-2019, 05:37 AM
74-07 74-07 is offline
Default Checklist
Thanks for providing Walt. I found your checklist a couple of weeks ago. I used it for the condition inspection which was just completed. Very complete! Highly recommend.
Old 01-22-2019, 06:52 AM
My thanks as well. I'm heading out to the airport this AM to review your list with my new mechanic. Robert
Old 01-27-2019, 06:53 PM
drill_and_buck's Avatar
drill_and_buck drill_and_buck is offline
Walt, I noticed an item on your CI checklist that was missing from mine. You have a line item to remove the prop (if constant speed) and remove sludge (if required). Can you elaborate on this item? Do you remove all CS props for inspection? I have not removed my CS prop since it was initially installed. Any gotchas with respect to introducing maintenance induced failures when performing this step?
Tks,
MD
Mike Draper
RV-8 N468RV
First Flight 11/13/2011
TMX0360, Pmags, CS
Bridgewater, MA
KPYM
