Old 08-25-2018, 01:32 PM
JoeB JoeB is offline
Default Dynon heated pitot install
Well after 2 year hiatus (move, new house, baby, deployment)
I am slowly starting back to work.....
I have the heated dynon pitot with AOA, and the gretz Mount,
Gretz/dynon recommendation is install near the inspection panel for later MX.
The standard vans location is further outboard. Gretz also stages “not too close to tie down” a little vauge.
What has this set up ?
Where was your install location?
Does it work there or “I wish I would have...”
Picture would also help
Thank you!!
Joe
Old 08-25-2018, 03:08 PM
Kiwi flyer Kiwi flyer is offline
Installed mine this morning on qb wings, had the same questions. What I did as have many was to place it by the rib just outboard of the further outboard inspection panel . This keeps it clear of the aileron bell crank, although it is still close to tie down, one rib outboard. Putting the heat controller on back of inspection panel. Hope this helps. Pete
Finishing kit started.
Old 08-25-2018, 03:23 PM
lr172 lr172 is offline
I did similar to Kiwi. Installed in the outboard bay adjacent to the furthest bay with inspection panel. I installed on the outboard rib if that bay. I feel this is adequately far from the tie down, though not optimum. Didn't want it too far from access.
N64LR
RV-10 in progress
Old 08-25-2018, 08:30 PM
Thank you
I think I will also do 1 rib outboard of the panel
Old 08-27-2018, 05:03 PM
rjarrell's Avatar
rjarrell rjarrell is offline
Default Dynon Heated AOA Pitot tube service letter
Verify you are not affected by Service bulletin from 2014 #101014 before you mount. Just sayin
Rodney RV-10 "LIBERTY"
Dues paid 2018
Old 09-10-2018, 03:22 PM
Janekom's Avatar
Janekom Janekom is offline
I have installed several on the inspection panel. Never had a problem, altough it is close to the tie down.
Jan Hanekom
South Africa
Approved Person nr 325
http://www.rvbits.com
RV10 - ZU-XOX - (Flying)
RV7A - ZU-JRV - (Flying)
RV10 - ZU-JVR - (Written off)
RV7 - ZU-LOL - (Flying)
RV10 - ZU-RVI - (Flying)
RV7A - ZU-MER (Bought back)
RV7A - ZU-JAD (Sold Flying)
Dues paid for 2019
Old 09-10-2018, 03:48 PM
Dustyone Dustyone is offline
Same as Jan on the last 4 RV-10's.
Easy access for future maintenance.
( Dynon mast shown in these photos )
Ashley Miller
RV-10 #40597
Dual SDS CPI
http://www.vansairforce.com/communit...d.php?t=140051
Airflow Systems Air-Con
http://www.vansairforce.com/communit...4&postcount=15
VH-XTE 500hrs +
Redcliffe,Brisbane
Australia
Photos : https://goo.gl/photos/zsfBeVofHMe4ze7i7
