Old 09-06-2018, 12:26 PM
Originally Posted by mturnerb View Post
Good point Scott. Question: I am installing jettison handle, but only intend it for use as emergency ground egress - no intention to do aerobatics or carry a 'chute. Would you agree that a plastic piece should be "defeatable" to remove canopy on the ground if latch is not usable?
If the latch is not usable, It wouldn't matter whether the hinge cover was defeatable...... So I guess I don't understand your question...
Scott McDaniels
Hubbard, Oregon
Old 09-06-2018, 12:44 PM
mturnerb mturnerb is offline
Assuming aftermarket hinge covers are in place: if jettison handle is pulled, thereby releasing hinges, could forward canopy be pushed/pulled up (using reasonable force) for emergency ground egress?
Turner Billingsley
RV-14A In Progress
N14VB Reserved
Old 09-06-2018, 01:58 PM
I can't answer that because I have not physically seen the part being discussed but since the photo shows a screw and a clamping block my guess would be the answer is no.
If the standard kit supplied covers are used the answer is yes.
Scott McDaniels
Hubbard, Oregon
Old 09-06-2018, 05:56 PM
Wild dogg Wild dogg is offline
Default Covers
The plastic covers will brake out very easily you will see two small labs on the nut you instal first I tested that already his sight is Rv plastic.com to remove rember to take that plastic nut out or you will brake it he supply a tool to remove it I have they work great
Old 09-06-2018, 06:30 PM
Bavafa Bavafa is offline
Did you paint yours? I ordered a set and then I learned they can not be painted if there is acetone or solvent in the paint. I will be painting my plane with Base/clear which does have solvent in it.
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - Flying
Dues paid
