Old 08-24-2018, 09:52 PM
Tacco Tacco is offline
Default Step Caps
I think I saw where the 12i has end caps for the WD-1233L&R steps. Anyone know the part number?
Old 08-24-2018, 10:22 PM
DHeal DHeal is offline
I purchased some black plastic end-plugs that fit the RV-12 step ends perfectly. See my old VAF forum entry below:
If you want to fill those somewhat unsightly tooling holes on your RV-12's wing tip bows and stab end ribs, you might want to use the following finishing caps:
-- Hillman Arrow Clips - Nylon (White) #394150-C (for the 3/16" holes)
-- Hillman Arrow Clips - Nylon (White) #394148-A (for the 1/8" holes)
I found the above clips at my local ACE Hardware store.
To seal-up the ends of the foot steps, I used the following plastic end-plugs:
-- Hillman Round Cap Plugs (Black) 3/4"
I found these end-plugs at LOWE's.
EAA #23982 (circa 1965) - EAA Technical Counselor and Flight Advisor; CFI - A&I
RV-12 E-LSA #120496 (SV w/ AP and ADS-B) - N124DH flying since March 2014 - 725+ hours (as of Jan 2019)!
VAF donation through June 2019.
Old 08-24-2018, 10:47 PM
Gandalf Gandalf is offline
Warning: Not FAA approved for in flight use:
Old 08-25-2018, 12:29 AM
DaleB's Avatar
DaleB DaleB is offline
Dale
Omaha, NE
Previous RV-7 project (sold)
