Old 08-23-2018, 01:01 AM
Av8rRob's Avatar
Av8rRob Av8rRob is offline
Default Outboard leading edge construction question
So, Im thinking about the assembly and riveting of the outboard leading edge got me thinking. Is there any reason I cant back rivet the j-stiffener to the top skins firsts, then slide each rib in to its position prior to riveting them next? What can I say, I like back riveting and will do it when possible 🤪
Rob Lasater
Rv-14 still workin
Paid nov 2018
Old 08-23-2018, 04:52 AM
Bgill Bgill is offline
Default OB LE construction ?
I considered that approach in a few locations. The reason I did not - is the one rivet in each rib that sits somewhat under the stringer J channel. That rivet is somewhat hidden and difficult (not impossible) to set and inspect.
Working on the same LE section now..
Byron
RV-10 40253 N253RV Flying
RV-14 140466 In build - Wings
Douglas, GA
Old 08-23-2018, 03:22 PM
Av8rRob's Avatar
Good point. Oh well I guess Ill stop trying to outsmart the plans 🙄
Rob Lasater
Rv-14 still workin
Paid nov 2018
