Old 08-22-2018, 09:47 PM
rolick22's Avatar
rolick22 rolick22 is offline
Default New parts not included with RV-12iS kit?
When I was working on the RV-12iS OneWeek Wonder I noticed that a rub strip (1st Photo RED arrow). On the red RV-12iST I noticed that a pair of plastic vented handles (2nd Photo RED arrow) do not appear to be Part of my RV-12iS Kits. Any one have them in there kit? See photos below
______________________________________
David Rohrlick
PPSEL A&P
RV-12 Finished (Empennage, Fuselage(1st gen), and Wing kit)
Empennage finished (need to add the panel cut out)
Wings finished (need to add the left landing light)
iS Finishing Kit In work
iS Fuselage Finished
iS Engine Kit ordered
iS Avionics Kit ordered
1st GEN FUSELAGE SOLD
Serial#12-0864
N112DR Reserved
VAF donation made for 2019
Old 08-22-2018, 10:12 PM
rv9builder rv9builder is offline
They weren't in my iS fuselage kit. I haven't ordered the finish kit yet.
RV-12iS Fuselage
RV-9A Project: Sold
Old 08-22-2018, 11:51 PM
The vent handles were a late enough development that the decision was made to not let them delay release of the fuselage or finish kit so I think they were rolled to the avionics kit.
The part you are referring to as a rub strip should be part of the finish kit (if I remember correctly)
Scott McDaniels
Hubbard, Oregon
Old 08-23-2018, 05:58 PM
STEVEM STEVEM is offline
The rub strip was included as part of my 12is fuselage kit, which was received in April 2018.
Old 08-23-2018, 06:52 PM
rolick22's Avatar
What kit was it in? Got a part number? Want to check my inventory sheet.
David Rohrlick
PPSEL A&P
Serial#12-0864
N112DR Reserved
Old 08-23-2018, 07:44 PM
The rub strip is a length of UHMW plastic, pressure sensitive on one side, and adheres to the back of the wing spar center section. The part number is F-01204N.
Old 08-23-2018, 09:48 PM
rolick22's Avatar
Thanks STEVEM I will have a look.
David Rohrlick
PPSEL A&P
Serial#12-0864
N112DR Reserved
Old 08-23-2018, 11:48 PM
I said in Post #2 that I didn’t receive the “rub strip,” but I was wrong. Now that I know the part number, I rechecked my inventory sheet, and the F-01204N did ship with my fuselage kit. F-01204N is actually called a fuel tank pad and is listed under sub-kit 5. It is shown on drawing 21iS/U-01, but I didn’t see where it is installed in the written instructions.
A note on drawing 26iS/U-08 says the fuel tank will be in and out of the fuselage while installing the fuel system, so perhaps the F-01204N tank pad is installed when we mount the fuel tank for the final time.
The smaller F-01241 fuel tank pads are match drilled on drawing 21iS/U-02, and there is a note on drawing 21iS/U-03 that says you can delay installing the F-01241 pads until after painting the interior. My guess is that we install the F-01204N after painting, too.
RV-12iS Fuselage
RV-9A Project: Sold
Old 08-25-2018, 12:26 AM
Rob H Rob H is offline
I installed the adhesive strip on my iS fuselage kit as called out in Section 21iS. I don’t have it in front of me right now, but I think it was one of the last steps in the section. My strip was coiled and I had to lay it out between a couple of planks to get it to lay flat. I cleaned the surface well and used multiple clamps to hold it in place for several days. There are still areas where it doesn’t seem to stay adhered completely. I may need to remove and try a more aggressive adhesive or possibly when the tank is installed it may be pressed against it anyway. Maybe someone can chime in who’s beyond this step.
RV12 - building
Empennage finished
Wings finished
iS Fuselage in progress
ULS Fuselage kit - SOLD
Farmer - corn & soybeans
Firefighter
2018 Dues Paid
Knoxville, IL
Old 08-26-2018, 03:35 PM
rolick22's Avatar
Thanks guys after a short search I have found the F-01204N and I have it really to install. As it turned out somehow I overlooked that step. I like the new vent handles hope we can get them in the Avionics kit. Happy Building Everyone!!
David Rohrlick
PPSEL A&P
Serial#12-0864
N112DR Reserved
