Old 08-19-2018, 04:48 PM
PokePilot's Avatar
PokePilot PokePilot is offline
Default Some minor VS skin damage...
I'm in the process of setting up my workshop and I've been keeping my skins in the box in which they came. Well, I noticed a bend in the lower right corner of my VS skin and discovered that it had punched right into the side of the cardboard, resulting in an about 8 degree bend through the first prepunched hole. An amazing discovery when I just got the kit a week and a half ago and haven't even received my tool kit yet
I took a wood block and a mallet to it and gently tapped it back into shape, but there's still a tiny amount of deformation to that corner. I don't think it will affect anything structurally – it's bent slightly inward toward where the VS spar will be and the damage is really only visible from a distance if the light catches it. If anything I think it's just a cosmetic issue at this point.
I know the usual advice is to "flatten it out and build on", but does anyone recommend replacing the skin? For $85 plus shipping I don't know if it's worth scrapping an otherwise perfect skin for one tiny corner, but I'm open to suggestions.
Tyler Rafferty
Bentonville, AR
RV-7 #74747– empennage in progress
justanotherrv7build.blogspot.com
Old 08-19-2018, 05:46 PM
Mark Dickens's Avatar
You're right...build on!
RV-8 #81077 Super Slow Build
Titan IOX-370, Dual P-Mags, AFP FM200A FI, Sensenich GA Prop
First Flight 11/20/2016
www.marksrv8.com
Old 08-19-2018, 05:54 PM
Larry DeCamp's Avatar
Larry DeCamp Larry DeCamp is offline
Default Cosmetic
Bend it flat and move on. Thats heavy fill primer and sanding block is for !
Larry DeCamp
RV-3B flying w/ carb & Pmags
RV-4 fastback w/ Superior EXP 0360 /AFP & CPI
Clinton, IN
Old 08-19-2018, 06:00 PM
jcarne's Avatar
jcarne jcarne is offline
I agree, I would not replace that. Unless of course you plan on polishing but idk who actually does that sort of thing.
Jereme Carne
PPL
RV-7A Emp. done
Wings mostly done
Fuselage almost done
Finish kit arrived
Exempt but gladly paying!
Old 08-19-2018, 06:39 PM
mfleming's Avatar
mfleming mfleming is offline
Default Repair technique
Here’s a video of how I worked a similar crease out of some sheet metal.
https://m.youtube.com/watch?v=odRe9k...ature=youtu.be
Michael Fleming
Joseph, OR
sagriver at icloud dot com
RV-7 Slider #74572
Started 11/2016
Donated and so should you
Old 08-19-2018, 06:43 PM
Gently bend it out. You should avoid a hard edge for whatever you're using on the convex side of the bend. A nice radiused block of wood is good, with the radius under the bend and shaped to match it. I'd use another block on the concave side to - as I said - gently flatten the skin. Use your hand to press the second block as needed. No fancy tools for this one.
If ultimately you're still unhappy with it, check to see if this part is hidden under the tail fairing. If so, build on.
Otherwise, if you run out of any local resources, sure, go ahead and replace it. Us RV builders often do that, or at least I seem to. I've got a whole area in my garage attic reserved for scrap.
Skinning my RV-3B fuselage
Old 08-19-2018, 06:48 PM
Default Dimple
I think when you dimple that hole a lot of the creAse will come out. Also if you edge break the edge will stay down too. I think it will be very hard to see on the finished bird. JMHO
John S
Dues paid 2019, worth every penny
Fuselage 30%
Old 08-19-2018, 07:13 PM
PokePilot's Avatar
Ah, I didn't even think about the tail fairing. The damage is already pretty difficult to see, but it looks a lot worse in the pictures than it does in person. I'm pretty sure most of it will be hidden by the fairing and paint. I might play with it a bit more to flatten it further but ultimately I think I'll keep the skin. Thanks!
Tyler Rafferty
Bentonville, AR
Old 08-20-2018, 09:38 AM
airguy's Avatar
airguy airguy is offline
Build on. I've got worse than that on my airplane, a good many of us do.
Greg Niehues - PPSEL, IFR, Repairman Cert.
Garden City, TX VAF 2019 dues paid
N16GN flying 360hrs and counting! Built an off-plan 9A with too much fuel and too much HP. Should drop dead any minute now.
Old 08-20-2018, 10:22 AM
mturnerb mturnerb is offline
I wish I could say I have no "dings" on my build but it would be a lie. A few errant hits with the rivet gun here and there. Bondo will be my friend.
Turner Billingsley
RV-14A In Progress
N14VB Reserved
