Old 08-17-2018, 12:33 PM
dwranda dwranda is offline
Default Canopy frame groin punch!!
Well I was ready to rivet the skin to my canopy frame today to get ready to glue the canopy to it next week. I had noticed the fit on the right side had changed a little, but I thought it had to do with the 3 strengthening pieces between the frame and skin. I put the blank panel in for the first time with the canopy frame installed and there was a huge gap near the middle on the right. I discovered the tube on the frame had cracked. Talk about a punch in the groin!! I have an email in to Vans to see if it's something that could be welded or if I have to replace it and start over. UGH!! This was also the first time I realized that that tube and the huge gap between it and the skin on the outer edges are visible from inside the plane. Now I know why guys use fillers to fill in that gap to make it look nicer. For some reason I thought that tube was behind the panel when the canopy closed.
9A in progress
Working on Finish kit!!
Mattituck TMXIO-360 red gold
Dues paid Dec 18
Old 08-17-2018, 01:46 PM
bruceh's Avatar
bruceh bruceh is offline
Looks like the countersink on that one was oversized and might have weakened the tubing.
Bruce Hill
RV-9A N5771H flown over 600 hours!
2018 VAF donator
EAA Tech Counselor
Old 08-17-2018, 02:05 PM
Yes that is a possibility!
9A in progress
Dues paid Dec 18
Old 08-17-2018, 03:17 PM
BillL BillL is offline
Default It can be welded.
I made a "u" shaped die to hold the tube and used a dimple die in avery hand squeezer to make dimples, then refined with a countersink.
I did some welding on this piece, but not the tube, it will take some skill.
Bill
1st Flight 1-27-18
Phase II 8-3-18
Repairman 11-15-18
Instrument Currency 12-17-18
Old 08-17-2018, 07:22 PM
bluskydreamin bluskydreamin is offline
Default dont sweat it!
I broke this tube in half trying to "adjust" the tip up frame to the rest of the fuselage on a -7 build. Took it to a local machine shop that did TIG welding. I dropped it off on my way to morning coffee and $30 - 30 minutes later.... it was like new. Press on! The canopy of the pre -14 era can be a source of endless patience testing fun....
Old 08-21-2018, 09:20 AM
sblack sblack is offline
Easily weldable with tig or torch (I do both). Just bring it up to Montreal and I will do it for free . Walk into any welding shop with cold hard cash and they will do it, likely for a $20 bill. Clean it up, redrill and build on.
Most people are just gluing the canopy on now - avoids cracking. Worth considering. Search on sika flex.
Scott Black
RV 4, with an engine...and other stuff
VAF dues 2018
Old 08-21-2018, 09:51 AM
I called shops around town and have an appointment tomorrow to get it welded. I am going to use Sika. I thought I would be doing that this week, but the crack held me up.
9A in progress
Dues paid Dec 18
