Old 08-15-2018, 12:37 PM
burgessbuilderMO13 burgessbuilderMO13 is offline
Default Manifold pressure problem
Running a Van's manifold pressure gauge system on a 7A , O-360 A1A. It has worked fine for years and close to 500 hours. Now it indicates atmospheric on the ground, but never drops below 25" when running.
The needle does move, but certainly not as it should.
Has anyone had a similar issue. I'm thinking the transmitter is toast.
Dale
Old 08-15-2018, 12:51 PM
longranger's Avatar
longranger longranger is offline
Could be a leaky hose between the port and the sender.
Miles (VAF# 1238, Paid up as of 2018)
RV-7 TU 904KM (reserved)
Wings Fitted and Finish Kit on site
Construction Log
Picasa: Empennage Album, Wings Album, Fuselage Album
1955 Cessna 170B flying since 1982
'To get something you never had, you have to do something you never did.' -Unk.
Old 08-15-2018, 12:56 PM
Jesse's Avatar
Jesse Jesse is offline
Sounds like a leak.
352-427-0285
jesse@saintaviation.com
Old 08-15-2018, 01:15 PM
N941WR's Avatar
N941WR N941WR is offline
If it is not a leak, you might want to change MAP sensor. We have had a number of them good bad. If you do not find a leak and want to change it, order the replacement from your EFIS manufacture.
Some of the cheaper sensors our customers have bought from their local auto parts supplier.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 08-15-2018, 02:20 PM
Default Man pressure
Notice in the OP that we are using the vans gauge, no Efis.
Lines have been checks, no leaks
Dale
Old 08-16-2018, 09:19 AM
longranger's Avatar
Just a thought: Did you check the line with pressure or vacuum? In my career in instrumentation I saw plenty of instances when a line would hold pressure but wouldn’t hold a vacuum.
Construction Log
