Old 09-02-2018, 10:26 AM
N804RV's Avatar
N804RV N804RV is offline
I suspect the elevator trim tab is probably the #1 open stock purchase from Van's. I made a total of 4 attempts on my elevator trim tab. And, I finally just accepted #4, even though it wasn't perfect.
Using the form block inside the trim tab, wedged into the V jig didn't work for me. The whole thing kept moving no matter how much I tried to wedge and clamp. One thing I concluded is that the size and shape of the form block isn't as critical as securing the form block to the work piece and both to a solid surface so that it doesn't move. And, the bend line must be as accurate as possible.
I used my heavy steel backriveting plate to form the tab bend lines. I secured the trim tab under the steel plate with a couple of C-clamps on the edge of my work bench. And, I took my time in aligning the steel plate precisely to the bend line I marked on the trim tab with a fine point sharpie.
Then, I started the bend by hand, just pushing with my fingers until it was bent enough to work a 1 inch block (just a piece of wood from the scrap pile) under the edge. I then used the wood block and a mallet to finish the bend.
Ken W.
Mount Vernon, WA
2019 VAF Supporter
Old 09-03-2018, 07:50 AM
rvanstory's Avatar
rvanstory rvanstory is offline
Originally Posted by SteFree RV-8 View Post
Any help is appreciated. If nothing else, does anyone have a good set of pictures for how they did this?
Steve, I feel your pain! I had the same frustration with this. Here is a post of how I overcame the obstacle. In my opinion, the problem starts with the Van's wedge. Once I abandoned their method, it turned out to be a non-event.
http://www.vansairforce.com/communit...d.php?t=149675
Hope this helps!
Randy Vanstory
Building RV10
N783V - Reserved
Flying Mooney M20J
Emp Kit Completed, Tail Cone Attached, QB Wings delivered and starting Fiberglass Top.
Donation Happily Made 2019
