Old 08-17-2018, 09:58 AM
tomkk's Avatar
tomkk tomkk is offline
... A spare is on the shelf in the hanger, so no downtime…
I actually carry my spare in the airplane with me ...
Tom
Port Orange, Fl
RV-12 N121TK ELSA #120845; first flight 06/10/2015
RV-12 N918EN ELSA #120995 Eagles Nest Project
SPA Panther N26TK in progress
Old 08-19-2018, 12:40 AM
I carry a spare volage regulator and a spare mechanical fuel pump in the plane so I don’t get stranded somewhere. I also carry a couple of spark plugs and some common AN hardware.
Old 08-19-2018, 03:30 AM
RFSchaller - I looked at your VAF profile to see if you were a traveling salesman in a previous life...
Hinckley, Ohio
EAA #499867
80 hrs Flying Aeronca Chief 11AC N68203
RV-12 Bought Flying Oct 2015 with 48TT - Hobbs now 409
LSRM-A Certificate 2016
Special Thanks to EJ Trucks
Old 08-19-2018, 09:39 PM
Piper,
Don’t I wish! I’ve heard all the stories about farmers’ daughters and traveling salesmen!
Rich
Old 08-24-2018, 08:55 AM
RV12Roger RV12Roger is offline
Default Cooling regulator.
Biannual yesterday and saw “12 volts and dropping, -3 amps”???
Assume voltage regulator.
Is mounted in the cockpit.
1- Has anyone mounted a computer muffin fan with 4 standoffs/spacers blasting directly on the regulator! Ample cool air in the area from the vent. Simple solution?
2- What is a good replacement besides Ducati. John Deer ?.
Part number and vendor please.
Thanks.
Old 08-24-2018, 10:54 AM
Search eBay for AM101406" or "MIA881279" for John Deere $20 clone.
If you are in a hurry, NAPA 7068102 for $95.49, but it looks identical to $20 one.
Whatever you buy, mount it using heat conductive paste.
Joe Gores
RV-12 Flying
Old 08-24-2018, 11:01 AM
funflying funflying is offline
Joe,
I have read posts mentioning the heat conductive paste. Do you have more information about the paste? Brand, where to purchase, and it is applied to the mating surfaces? Thanks
Patrick Claar
Arvada, CO BJC
RV12, #401, Flying 2013, N612PC
RV6, 1996-2010 sold
Old 08-24-2018, 11:02 AM
tomkk's Avatar
That was my first try. I couldn't figure out a decent fan mounting that created airflow ACROSS the fins and ended up with a mounting that blew air from the bottom UP into the fins. That didn't create very much of a cooling effect. The blast tube I ended up using creates a lengthwise flow across the fins that seems to be doing a pretty good job so far. The tube was way easier as well ...
Tom
Port Orange, Fl
Old 08-24-2018, 11:41 AM
DaleB's Avatar
DaleB DaleB is offline
Originally Posted by funflying View Post
Joe,
Why not just use a dab of the same paste used for your spark plugs? I don't know that you're really going to get a solid enough contact area between regulator and sheet metal other than in the immediate vicinity of the mounting bolts. When I tried the JD clone regulator, I fabbed a mounting adapter plate so I could use my existing bolt holes. I used a little heatsink paste between the regulator and the mounting plate, which was a chunk of 1/4" AL. I don't know whether it did any good or not.
Dale
Omaha, NE
Previous RV-7 project (sold)
Old 08-24-2018, 12:03 PM
Joe,
The same paste used on spark plugs can be used. Search for heat or thermal conductive paste.
I found it on Amazon and Home Depot websites. Your local computer store has it for mounting CPUs.
Use the paste between the regulator aluminum case and mounting surface (airframe). Some brands contain
silver, but they are not much better than the cheap stuff.
A perfectionist might install a large 1/8" thick aluminum plate between the airframe and the regulator
with heat conductive paste between mating surfaces in addition to an air blast tube.
Joe Gores
RV-12 Flying
