Old 03-01-2015, 07:22 AM
dspender dspender is offline
Default Door latch indicator
Following the installation instructions for the latch indicator; as the magnet sets at the mouth of the latch pin my ohmmeter shows continuity. Following directions, as I advance the magnet deeper into the pin the continuity disappears. That is no different than if I did not have the magnet in the latch pin or the door was not fully latched. Can you explain in simple electrical terms, like 5th grade, why I need to advance the magnet into the latch pin until the Reed Switch opens, ie shows no continuity?
Dennis
Old 03-01-2015, 07:47 AM
N427EF N427EF is offline
The door open warning lights will be ONin your panel as long as there is continuity across the reed switch
When the magnet closes in on the switch and opens the contacts, the electrons stop flowing to the relay and the relay turns the light off in panel.
Without the magnets your lights would stay on.
There are many variation on installing these but this is what Van intended.
Keep it simple.
Ernst Freitag
RV-8 finished (sold)
RV-10 Flyer 400 plus hours
Over 2500 Gallons of E10 mogas burned
Don't believe everything you know.
Old 03-01-2015, 08:35 AM
Nukeflyboy Nukeflyboy is offline
Yep, that is right. Relay/switch contactors are either "normally open" or "normally closed", which describe their de-energized state (or un-magnitized). A normally open conact closes when energized (like a relay) or closes when magnitized (as in a reed switch). Some relays have both connections and they are labeled NO or NC.
This gives you a lot of wiring options.
Dave Moore
Granbury, TX
RV-10 and Breezy
Old 03-01-2015, 08:39 AM
9GT's Avatar
9GT 9GT is offline
I discarded my Van's magnetic switches and used normally "ON" micro switches that make contact with the tips of the latch pins. I have them adjusted so they do not break contact until the pins are fully engaged and the interior door handle is locked in full closed position.
David C.
Howell, MI
RV-9A: Under Construction.
RV-10: Completed 12/29/2013 SOLD 08/23/2016
"Donor Exempt" but donated through Dec. 2019
Old 03-01-2015, 08:48 AM
Yes, folks are used to energizing a relay to turn something on.
In this case, the relay is being used to turn the lights off when energized.
Vans does this by using the NC contacts to power the light through the relay.
Old 03-01-2015, 10:11 AM
This is the instructions included with the kit. See if the bolded area gives you any trouble like it is giving me.
5. Close and fully latch the door
6. Connect a continuity tester or Ohm Meter to the two wires on the rear switch. In its current state with no magnet present, the switch is open and will measure no continuity or infinite resistance.
7. Slide the magnet that was supplied with the Magnetic Reed Contact Switch in the Aft latch Pin. As you insert the magnet you will see evidence on the tester of the switch closing. Use something non ferrous to slide the magnet forward in the latch pin until the switch opens. Take note of the depth you push the magnet into the latch in.
8. Slip something ferrous in the Aft Latch Pin and pull out the magnet.
9. Unlatch and open the left door. Apply epoxy into the latch pin. Close and latch the door. Insert the magnet into the end of the latch pin. Use something nonferrous to slowly slide the magnet forward in the latch pin until the tester just indicates that the switch opens. let the epoxy cure.
My concern is if I slide the magnet forward in the latch pin until the tester just indicates that the switch opens, the indicator lights would suggest the door is not latched. I believe I need to slide the magnet in enough so that just before the tester would indicate open, I stop before that point. What do you think?
Dennis
Old 03-01-2015, 10:21 AM
Bill.Peyton's Avatar
Bill.Peyton Bill.Peyton is offline
The reasoning for using the normally closed switch is the default switch condition creates continuity without the use of a relay. To extinguish the door open light, the magnet must be inserted next to the reed switch to cause it to close.
I too used a micro switch rather than the magnetic switch. My switches will not make contact unless the pin is fully engaged.
Bill Peyton
RV-10 - 950 hrs
First Flight Oct 2012
WA0SYV
Aviation Partners, LLC
Old 03-01-2015, 12:41 PM
The system is design the way it is, to prevent the possibility of a system failure giving a false indication that the door was safe when it was not.
If the supplied switches and relay are used, a shorted or broken wire, anywhere between the relay and the switches should be unable to produce a false positive that a door is latched.
Scott McDaniels
Hubbard, Oregon
Old 03-01-2015, 01:50 PM
BigD BigD is offline
Re-read Mike and Bill's answer - I think you're conflating the switch being open with the door indicating (or being) open.
It is confusing.
==dave==
Old 03-01-2015, 02:13 PM
Have you read all of the instructions? I do not recall exactly but I thought after the epoxy dried I adjusted the sensor position to get it to just close contacts with the door closed.
