Old 01-11-2015, 10:25 AM
Ron B. Ron B. is offline
Default Rudder cable bushings
I have not riveted the baggage floor as in Canada we need a pre-closure inspection preformed. I have moved on to the next steps and got to the point of installing the rudder cables and the snap bushings. It was a lot easier to undo all the clecos and remove the floor than to twist my arm thru the lightening holes to install them. For those not to this point I would suggest looking ahead and install the snap bushings and perhaps push the rudder cables thru as well. Not saying it cannot be done as per plans.
Thanks Ron
RV-10 SOLD
RV-14 Flying
Old 01-11-2015, 05:11 PM
jswareiv jswareiv is offline
Default Adel clamps on rudder cable
Now tell me how you are going to get those forward adel clamps installed with the bolts. I opted for AN3-4A verse using the 3's. Trying to get the washer and nut on there in limited space where you can't see it, has proved difficult so far. I got three of the four in, but the left side forward is impossible, not impossible, but a pain in the ***! The adel clamp keeps wanting to spring open and launch the washer. Suggestions?
Stoney
First RV-14 Flight 04/17/2016
Serial #140087, N214SW
Old 01-11-2015, 06:32 PM
I cannot find the part number , but do you have a flat thin bar with a slit that you slide over the threads of the bolt after it passes thru the Adel clamp. You can actually thread the bolt and this flat bar acts as a nut and tightens the clamp a little. This holds things in place and you slip the washer and nut on and once the nut is started you just pull the flat bar out.
Someone will have a name for this tool and a part number. I plan on using it when I get back to the rudder cables after inspection completed.
Thanks Ron
RV-10 SOLD
RV-14 Flying
Old 01-12-2015, 06:39 AM
I cannot find the part number , but do you have a flat thin bar with a slut that you slide over the threads of the bolt after it passes thru the Adel clamp. You can actually thread the bolt and this flat bar acts as a nut and tightens the clamp a little. This holds things in place and you slip the washer and nut on and once the nut is started you just pull the flat bar out.
That would be much appreciated. My hands are shredded from working in that space. Thanks.
Stoney
Old 01-12-2015, 08:17 AM
Mike H Mike H is offline
A small drop of super glue works well to secure washers to the bolt head. It also works well to glue a washer and nut to the tip of you're finger to keep the hardware aligned while you start the nut, then you can roll you're finger and the glue and hardware will peel off.
Mike Hammond
A&P IA PPL ASEL
RV-14A kit S/N 140170
Old 06-02-2016, 05:06 PM
Junk8 Junk8 is offline
Default Rudder cable claps
I solved this problem by bending a 1/4 inch wrench about 30 degrees. It let me access areas my fingers couldn't.
Old 06-03-2016, 02:39 AM
salto salto is offline
To assist with the installation of adel clamps just use some tie wire to hold the tabs closed enough to get the nut started. Cut wire away, position the tube and tighten up. You can fight those adel clamps till the cows come home if you don't do something like this. Also found using the fuselage rotisserie so you can drop washers in place and brain surgeon like dexterity also helped.
Kit 140241
Tail Feathers done
Fuselage kit completed.
wings almost complete.
Flaps and ailerons done.
Canopy next. Phew!
Old 06-03-2016, 09:51 AM
aerhed aerhed is offline
Ron, I think I could use a good bar with a slut. Where it at?
Actual repeat offender.
Old 06-03-2016, 10:04 AM
It's called an Adel clamp keeper. I looked it up and ACS must have sold them but I do not see them on the site now. There are pictures if you google them. Good luck.
Thanks Ron
RV-10 SOLD
RV-14 Flying
Old 06-03-2016, 10:09 AM
Ron,
Reread his post, I think he was making fun of the misspelling of slit, was spelled slut.
Stoney
