Old 09-13-2018, 02:10 PM
rvmv rvmv is offline
Default TruTrac Gemini as PFD?
Would like to hear from gemini users regarding using it as my primary flight display. I am VFR day only and realize it does not have a true attitude indicator. Thinking about pairing it with an IFly gps. Thanks
Old 09-13-2018, 02:11 PM
Xkuzme1's Avatar
Xkuzme1 Xkuzme1 is offline
I think they are very good instruments, but IMHO, they have a reliability problem.
Tinker.
RV-4 - 0-320 (160HP)
www.KCFlight.org
Tinker
ATP/CFI/II/MEI
N617TN
Old 09-13-2018, 02:14 PM
Default reliability
Could you please expand on that ? thanks!
Old 09-13-2018, 04:02 PM
Xkuzme1's Avatar
It works good when you park it, then next time you fly itís cold, it locked at 15 degrees of bank.
I never trusted my pitch and bank with that instrument.
www.KCFlight.org
Tinker
ATP/CFI/II/MEI
N617TN
Old 09-13-2018, 04:44 PM
Carl Froehlich's Avatar
Carl Froehlich Carl Froehlich is online now
If you are going to spend that much money, get a Dynon D10A and have a real EFIS.
Old 09-13-2018, 08:59 PM
Carlos151's Avatar
Carlos151 Carlos151 is offline
Had mine for about 20 hours and it went to a 90 degree bank angle on startup. No way to reset or cage it. Removed it and sent it back to TruTrak for warranty service. Itís worked flawlessly since then. Currently 280 hours on the aircraft. I use it as a standby attitude indicator. Primary is a Dynon FightDek 180. GPS source for heading input is from an iFly720. Any attitude indicator can fail. IMHO with over 22k hours of flying, cross reference all instruments. Attitude indicators fail, solid state or vacuum, thatís why we practice and are trained for no gyro approaches. In a pinch, the iFly has a basic attitude indicator too.
Karl Richcreek
RV-8
N151TK "La Otra Chica"
Flying as of August 14, 2015
Old 09-14-2018, 09:58 AM
rleffler's Avatar
rleffler rleffler is offline
My opinion is that I wouldn't want a smaller screen EFIS as my PFD.
I have a Gemini installed as a backup and tie breaker EFIS. All I say is that I would choose another product if I was going to do it again.
I had problems getting it to pass certifications tests. Lucas wanted the aircraft to be warmed up to pass the test. After three years of complaining about failing the certification test, he finally swapped the unit out this past year. I haven't attempt to get the new unit certified.
Bob Leffler
N410BL - RV10 Flying
http://mykitlog.com/rleffler
Old 09-14-2018, 01:18 PM
bkthomps bkthomps is offline
my answer? Absolutely not
would you fly with this?
https://www.youtube.com/watch?v=S_tlSfHS4Vo
https://www.youtube.com/watch?v=eLRo9gtYf-M
I have had no issues with my Garmin G5 that replaced it, and I cannot recommend the Gemini to anyone
Old 09-14-2018, 07:39 PM
rocketbob's Avatar
rocketbob rocketbob is offline
I put one in the RV-6 about five years ago, and over almost 500 hours it never gave a false indication or misbehaved.
Bob Japundza CFI A&PIA
N55BC RV-6 borrowed, flying
N678X F1 Rocket, under const.
N244BJ RV-6 "victim of SNF tornado" 1200+ hrs, rebuilding
N8155F C150 flying
N7925P PA-24-250 Comanche, restoring
Not a thing I own is stock.
Old 09-14-2018, 09:05 PM
Tom Martin Tom Martin is offline
I think there are better options now. For my eyes it is too small. Check out the Garmin G5
CPL & IFR rated
EVO F1 Rocket 1000 hours,
RV14 Tail dragger
Fairlea Field
fairleafield@gmail.com
