Old 09-02-2018, 12:47 PM
Girraf Girraf is offline
Default Day 1 - Already an issue
First day of many and already need an opinion. I was test fitting the horizontal stab rear spar reinforcements and noticed that the 2 pieces that butt up together to form the spar don't exactly line up. They are about .035" askew. When I lay them end to end without the reinforcement, they are exactly the same size, but as soon as I cleco the supports in there, the parts shift. Is this normal variability in production? It looks to me as though the holes that are punched in the spar halves are in fact just slightly off from eachother.
RV-7:
Working on Empennage
Wings Delivered
Old 09-02-2018, 01:07 PM
BigJohn BigJohn is offline
Not getting pictures.
John Peck, CFII, A&P, EAA Tech Counselor, Flight Advisor.
“Master Pilot” Award, UFO Member.
RV-12 N37JP 120176 Flying since 2012.
One Week Wonder Build Team, OSH 2018.
VAF paid through 10/2019.
Old 09-02-2018, 01:17 PM
N804RV's Avatar
N804RV N804RV is offline
Can't see your pics.
The tapered spar reinforcements have to be radiused to fit into the flanges in order for the match holes to line up. Also, all tooling marks and extra material needs to be filed off. I used a 3M deburring wheel on a bench grinder for this.
With the proper radius and all the holes lining up, you will still have a small gap, end to end between the spar halves.
Ken W.
Mount Vernon, WA
2018 VAF Supporter
Old 09-02-2018, 01:33 PM
At the time these photos were taken, the appropriate edges have been broken to get them lying flat inside the spar, all 4 ends radiused around the end holes, but only 1 has been fully polished. I don't believe the offset is caused by the incomplete finishing work on the reinforcements.
When I test fitted them, I had clecos in end holes as well so there shouldn't be any twisting going on.
RV-7:
Wings Delivered
Old 09-02-2018, 02:10 PM
RV7A Flyer's Avatar
RV7A Flyer RV7A Flyer is offline
It's metal...bend it to make it fit and square up the flanges.
2019 Dues paid!
Old 09-02-2018, 07:43 PM
longranger's Avatar
longranger longranger is offline
If you have properly radiused the bars to fit the radius of the channels (in this case it takes more than just breaking the edges) and have more clecos outboard make sure they are lined up properly, then one or the other of the spar channels is mis-bent or mis-punched. It’s rare to see that from Van’s but does happen occasionally. I had it happen with an aileron spar. They replaced it no questions after I sent pictures.
Miles (VAF# 1238, Paid up as of 2018)
RV-7 TU 904KM (reserved)
Wings Fitted and Finish Kit on site
Construction Log
Picasa: Empennage Album, Wings Album, Fuselage Album
1955 Cessna 170B flying since 1982
'To get something you never had, you have to do something you never did.' -Unk.
