What is the most common way to seal/join the canopy and the top of the skirt?
Rivets are done and filled with epoxy, aft joint is glassed, trimming is done, sanding is almost done and epoxy primer will follow.
I was thinking of applying a small bead of epoxy resin from front to back, both sides, to mainly prevent water from entering when dribbling down, or dust and air, etc...
