Old 05-06-2019, 12:01 PM
Rob H Rob H is offline
Default Next step?
Iím nearing the end of the RV-12iS fuselage kit. Iím at the section regarding fuel lines. I had Vanís prebuild my tank, so itís complete. Several of the instructions in the section regarding fuel lines and fittings require waiting for the engine kit. Would you recommend doing what I can with the fuel section right now? Or waiting until the engine arrives? And when did you order your engine? Iím slower than most builders due to work and family commitments, started May Ď16. I need to finish seat backs, rudder pedals, and sheet metal work at forward fuselage and after this itís on to the finish kit which I havenít ordered either. Just need some recommendations on how I should proceed. Thanks
RV12 - building
Empennage finished
Wings finished
iS Fuselage in progress
ULS Fuselage kit - SOLD
Farmer - corn & soybeans
Firefighter
2018 Dues Paid
Knoxville, IL
Old 05-06-2019, 12:10 PM
rcarsey rcarsey is online now
I assume you're talking about all the various tubes you need to bend, etc.
The ones that are behind the baggage bulkhead, you won't be able to install. But you can still make them now.
When I did my engine kit, I found that the tubes were fit very well.. and only only of them I needed to wrangle a little bit (just bending it by hand in a spot was sufficient).
Also, make sure that Section in your KAI is up-to-date.. they changed a couple of the tube bends recently (July 28 2018)
https://www.vansaircraft.com/service...evisions/27is/
Old 05-06-2019, 02:12 PM
Bob Y Bob Y is offline
Originally Posted by Rob H View Post
. ... And when did you order your engine? Iím slower than most builders due to work and family commitments, started May Ď16. I need to finish seat backs, rudder pedals, and sheet metal work at forward fuselage and after this itís on to the finish kit which I havenít ordered either. Just need some recommendations on how I should proceed. Thanks
Regarding your power plant kit ordering question, you will hav a lot of work to do on the Finish Kit, so certainly wouldnít order the Powerplant kit until the end of the Finish Kit is in sight. I ordered mine two weeks ago and am waiting for shipment confirmation and time now.
