Old 04-18-2016, 02:01 PM
Rayh Rayh is offline
Default Squeal with PTT
With only 9 hours in my 12 I started to get an intermittent squeal when I push my Pilot side PTT. Do not get it in the Co Pilot side. I set one of the soft keys on the Garmin radio to PTT and it doesn't squeal. Attempting to track it down. Any suggestions?
Ray in WV
N241RL
RV-12 806
Old 04-18-2016, 02:32 PM
ArVeeNiner's Avatar
ArVeeNiner ArVeeNiner is offline
I had a squeal during an intercom swap in my airplane the other day. Turned out it was one of the noise cancelling headsets. During my checkout of the installation, I had set the headset on the side of the fuselage (in the hangar of course) with one ear cup outside the fuselage and the other inside. This caused a squeal.
My suggestion is that if you are trying this with a noise cancelling headset, start your troubleshoting there.
Kelly Johnson
San Jose, CA
RV-9A
Pink slip issued: 5/7/12
First flight: 5/28/12, Memorial Day.
Phase I Complete: 8/18/12!
2019 donation: complete
Old 04-18-2016, 07:07 PM
Pat Stewart Pat Stewart is offline
Try the mic gain setting on the radio, go to the setup, key the mic and turn it down till the noise goes away. On mine the setting was 8
Built, RV 8, RV8A, RV 10, RV12, Purchased RV7A
Restored J3Cub and PA28R180
Pecan Plantation
Eagles Nest Mentor
EAA Tech Counselor
Old 04-18-2016, 09:04 PM
I will try that, thanks.
Ray in WV
N241RL
RV-12 806
Old 04-19-2016, 04:00 AM
BigJohn BigJohn is offline
The problem on one side only does suggest something specific to the wiring on that side. Perhaps a grounding problem? The insulators in the mike jack can be tricky. Just a thought.
John Peck, CFII, A&P, EAA Tech Counselor, Flight Advisor.
“Master Pilot” Award, UFO Member.
RV-12 N37JP 120176 Flying since 2012.
One Week Wonder Build Team, OSH 2018.
VAF paid through 10/2019.
Old 04-19-2016, 06:30 AM
Great thought. I will investigate that.
Ray in WV
N241RL
RV-12 806
Old 03-30-2019, 03:32 PM
magiccarpet's Avatar
magiccarpet magiccarpet is offline
Angry Same issue
It seems that I have the same issue.
I noticed a squel (kind of a feedback) when I transmitting. It's better when engine is off or at low RPM and gets worse at cruise power. However, it varys and it is difficult to track down, but at least very annoying.
I changed sidetone parameter and tried with different volume settings, both at the I/C and at the headsets, but doesn't seem to really help much.
I am using Bose A20 headsets for both seats and a this Inflight solution to feed I/C audio to my GoPro 5
My Radio is a Garmin GTR225
If somebody has solved this or could provide more pointers to tackle this, that would be great.
Somewhere I read that a ferrite core might help.
Chris, RV-12 S/N 120832, HB-YSC
flying
Facebook: http://www.facebook.com/magic.carpet.aviation
YouTube https://www.youtube.com/channel/UCLw...nv3vJiqAYoE-dg
=VAF= dues paid for 2019
Old 04-29-2019, 05:15 AM
Dgamble's Avatar
Dgamble Dgamble is offline
I had the same problem - it cleared up once I installed a dedicated ground wire on the female headset jack rather than counting on a washer in contact with the floor skin. It made a world of difference, but I'm not discounting the possibility that just fiddling with the jack fixed it. It also took out an annoying buzz in my videos when I did the same for the 1/8" jack that I use to capture headset audio.
Dave Gamble
Grove City, OH
RV-6 N466PG Purchased already flying - SOLD!
Built RV-12
http://www.schmetterlingaviation.com
The above web blogs and any links provided thereto are not instructional or advisory in nature. They merely seek to share my experiences in building and flying Van's RV airplanes.
Old 04-29-2019, 06:54 AM
Mich48041 Mich48041 is offline
Headset jacks and mic jacks and music jacks should be mounted with insulating step washers so that the jacks do not touch the aluminum mounting surface.
Joe Gores
RV-12 Flying
