Bought a partially completed 10. Previous owner was putting on a Subaru engine and plumbed the fur system with the Andair duplex valve allowing a return line. I'm using stock Vans fuel pump setup with stock injection and have no use for the return line. I'm assuming I can just cap the return lines? At the front of the Andair valve there are two fitting that go toward the fuel pump. Which one can be used and which is capped (or does it matter).
Also it appears that with the filter and pump I won't have a lot of room for the Red cube so I'll be mounting it firewall forward.
