Dynon Roll Servo Install.
ron sterba
Hi Guys. Hooking up Dynon wing servo and I found out one twisted pair needs 6-8 twists per foot and here's my Question. At the servo did you use spade connectors or Molex connector to the wiring harness at the servo?
QBRV9A
Ron in Oregon
Pins Only
I figure the servo is not coming in and out so I just used the DB9 pins and used heat shrink tube over each connection the one large piece over the entire bundle. If I ever have to remove it, i just cut away the heat shrink tube.
Ok Guys I got it. Looks like all will do the job just fine. I'll have to see whats for sale locally. Appreciate your ideas.
Ron in Oregon
