I've massaged the flaperon skins (trailing edge) to fit the ribs as close as I could. When I cleco'd them to the spar/rib assembly the skins are pretty flat on the top surface but have a slight concave bottom surface in places. I can get a .022" shim under a straight edge. As I understand Van's instructions, I would hold a block to the trailing edge and tap it with a hammer. Several questions:
1. Is 0.022" enough to mess with? Or wait and see how she flies?
2. Do you try to adjust it while cleco'd or do you wait until riveted? I have seen changes in fit between cleco'd and reveted.
3. Since one surface is pretty good, does the tapping technique work? I assume you'd tap biased to the curved surface.
4. Any suggestions as to how to secure the assembly while tapping?
Harlan H. Henke
RV-12iS Tail kit and wings complete.
2020 Dues paid.
Harlan H. Henke
2020 Dues paid.
