Two gps antennas
Tony M
Member
Has anyone ever put two GPS antenna is on an RV 12 IS? I have the issue of GPS 20A needs a GA 35 antenna and the Garmin G3X panels want a GA 56 antenna. I want to have touch display as back up GPS.
Or a better question can I just use GA57 antenna with both units with a splitter and that would also deal with xm that would be ideal?
I don't have an RV-12, but I do have 3 GPS antennas in my RV-7; GA 35 for the GTN 650, GA 26 for the G3X Touch GDU 460, and GA 37 for the G3X Touch GDU 465.
No issues or interference noted.
Cheers!
Without a very careful investigation, splitters should be avoided. (1) many antennas these days have a built-in amplifier. The receiver is looking for a specific signal level from the antenna, different boxes may have different requirements. (2) GPS signals are very weak, I wouldn't give up half the signal from a non-amplified antenna;(3) the amplifiers are powered by dc running up the coax. You'd need a splitter that didn't interfere with that, and could tolerate additional dc running up from the other receiver.
I have a GA 35 and GA 56 side-by-side with 6" separation on the tailcone just behind the turtle deck bulkhead of my -12. They work great there. You can see them in the first photo of the linked article.
RV-12 build article
